Metec FlatPCB Brailleline
Here is an example how to connect the FlatPCB cells.
Press the keys to turn on the pins. They are multi use.
#define CLK_H       PORTD |=  4     // D2   PD2  --> Clock             OUTPUT  (yellow)
#define CLK_L       PORTD &= ~4
#define STR_H       PORTD |=  8     // D3   PD3  --> Strobe            OUTPUT  (green)
#define STR_L       PORTD &= ~8
#define DOUT_H      PORTD |=  16    // D4   PD4  --> DataOut (Pins)    OUTPUT  (blue)
#define DOUT_L      PORTD &= ~16
#define DIN         PIND & 32       // D5   PD5  <-- DataIn (Keys)     INPUT   (purple)
const int cellCount = 8;
byte cells [cellCount];
byte keys  [cellCount];  // 1 = pressed, 0 = not pressed
  DDRD |= (4 | 8 | 16);   // Set as OUTPUT (1=RX, 2=TX,  4=D2, 8=D3, 16=D4,   32=D5, 64=D6, 128=D7)
  // DoTests();
  RWFlatPCB();
void RWFlatPCB()
  CLK_L;
  STR_H;  // Strobe on
  int index;
  for(int i = 0; i < cellCount; i++)
    if (i & 1) index = i-1; else index = i+1;   // change the cells
    for(int b = 7; b >= 0; b--)
      CLK_L;   if ( cells[index] & (1<<b) )   {DOUT_H;} else {DOUT_L;}     CLK_H;
  // Read the Keys
  CLK_L;
  STR_L;  // Strobe off
  for (int i = cellCount-1; i > 0; i--)
    if ( (DIN) == 0 )  keys[i] = 1;  else keys[i] = 0;
    CLK_H;  CLK_L;
    if ( keys[i] == 1 ) cells[i] = 255; else cells[i] = 0;    // Turn on the cell
  STR_H;  // Strobe on
void DoTests()
  // Lines down
  for(int j = 0; j < 10; j++)
    for(int i = 0; i < cellCount; i++) { cells[i] = 1 +8;   }  RWFlatPCB(); delay(100);
    for(int i = 0; i < cellCount; i++) { cells[i] = 2 +16;  }  RWFlatPCB(); delay(50);
    for(int i = 0; i < cellCount; i++) { cells[i] = 4 +32;  }  RWFlatPCB(); delay(20);
    for(int i = 0; i < cellCount; i++) { cells[i] = 64+128; }  RWFlatPCB(); delay(10);
  for(int i = 0; i < cellCount; i++) { cells[i] = 0;      }  RWFlatPCB(); delay(200);
  // X-Test
    for(int i = 0; i < cellCount; i++) { cells[i] = 1+16+4+128; }  RWFlatPCB(); delay(100);
    for(int i = 0; i < cellCount; i++) { cells[i] = 8+2+32+64;  }  RWFlatPCB(); delay(100);
  // On-Off
  for(int i = 0; i < cellCount; i++) { cells[i] = 255;    }  RWFlatPCB(); delay(500);
  // Every pin
    for(int b = 0; b < 8; b++)
      for(int i = 0; i < cellCount; i++) { cells[i] = (1<<b); }  RWFlatPCB();
  // All off
FlatPCB.ino (2.68 KB)
When you advertise your product, maybe you should mention somewhere that it is a braille line?
Yes it is a brailleline. :slight_smile: They are available with 6 and 8 cells. You can combine them to a larger one too.
There are more information:
What's the price tag?
You can get an offer about the parts you will need. It depends of the amount and where we should deliver.
Please write an email to contact@metec-ag.de
