Meteo pressure/temperature/humidity sensor
Hi! I am trying to build a simple weather station that has to always sit outside hanging on my wind turbine tower. So it is going to be enclosed in a hermetic case. This will require pressure/humidity sensors sit outside of the box but what I have seen so far are simple SMD chips that are not IP66/IP67 safe.
Can anyone recommend such sensors?
Thanks a lot in advance, Sergei
You need a Stevenson Screen to enclose your T and H sensors. The electronics can be in a fully weather proof box.
http://en.m.wikipedia.org/wiki/Stevenson_screen
Weedpharma
weedpharma: You need a Stevenson Screen to enclose your T and H sensors. The electronics can be in a fully weather proof box.
Weedpharma
Well, I see but still a sensor should not sit just on an SMD with open connectors, resistors around, etc. All of this will rust in a matter of days. This kind of screen will protect from direct rain but will not protect from fog which is bad for SMD.
A temperature, pressure, humidity sensor can only work if exposed to the air.
How else can it work?
Weedpharma
weedpharma: A temperature, pressure, humidity sensor can only work if exposed to the air.
Weedpharma
Of course, but when it is mounted on a an SMD like this http://www.dx.com/p/arduino-digital-temperature-humidity-sensor-module-121350#
it is too fragile to weather. I am looking for something more protected when there is a good and isolated casing for everything (paths on SMD, wires, etc.) except the sensor itself.
