Meu codigo da exit status 1 e parece que nao defini as bibliotecas?
#include <IRremote.h>
#include <PushButton.h>
// DIRETIVAS DE COMPILAÇÃO
#define tempoTecla 350
#define frequencia 38 // kHz
// DEFINIÇÃO DOS PINOS
#define pinReceptor 11
#define pinBot1 8
#define pinLed 12
// INSTANCIANDO OBJETOS
IRrecv receptorIR(pinReceptor);
IRsend emissorIR;
PushButton botaoLeitura(pinBot1);
// DECLARAÇÃO VARIÁVEIS GLOBAIS
bool lerComando = false;
// DECLARAÇÃO DAS FUNÇÕES DE LEITURA
void ircode(decode_results *results);
void encoding(decode_results *results);
void dumpInfo(decode_results *results);
void dumpRaw(decode_results *results);
void dumpCode(decode_results *results);
// DECLARAÇÃO DAS TECLAS CLONADAS
unsigned int teclaA[] = {8900, 4550, 450, 650, 450, 650, 450, 650, 500, 600, 500, 650, 450, 650, 450, 650, 450, 650, 450, 1750, 500, 600, 500, 1750, 450, 1750, 450, 1750, 500, 1750, 450, 650, 450, 1750, 450, 650, 450, 650, 450, 650, 500, 600, 500, 1750, 450, 650, 450, 650, 450, 650, 450, 1800, 450, 1750, 450, 1750, 450, 1750, 500, 600, 500, 1700, 500, 1750, 450, 1750, 450};
unsigned int teclaB[] = {8900, 4500, 500, 650, 450, 650, 500, 600, 500, 600, 500, 650, 450, 650, 450, 650, 450, 650, 450, 1750, 500, 600, 500, 1700, 500, 1700, 500, 1750, 500, 1700, 500, 650, 450, 1750, 450, 650, 500, 600, 500, 1700, 500, 1700, 500, 650, 450, 650, 500, 600, 500, 600, 500, 1700, 500, 1750, 500, 600, 500, 600, 500, 1700, 500, 1700, 500, 1750, 500, 1700, 500};
unsigned int teclaC[] = {8900,4500, 500,600, 500,650, 450,650, 450,650, 450,650, 450,650, 500,600, 500,600, 500,1700, 500,600, 500,1750, 500,1700, 500,1700, 500,1700, 500,650, 450,1750, 500,600, 500,600, 500,600, 500,1700, 500,650, 450,650, 500,600, 500,600, 500,1700, 500,1750, 450,1750, 500,600, 500,1750, 450,1750, 450,1750, 500,1700, 500};
unsigned int teclaD[] = {/COPIE_OS_DADOS_DENTRO_DAS_CHAVES_DO_MONITOR_SERIAL_E_COLE_AQUI/};
pinMode(pinLed, OUTPUT);
// INICIANDO RECEPTOR IR
receptorIR.enableIRIn();
Serial.print("Setup Concluído");
// MÉTODO PARA LEITURA E ATUALIZAÇÃO DAS PROPRIEDADES DO BOTÃO
botaoLeitura.button_loop();
// BLOCO CONDIÇÕES PARA INICIAR LEITURA
if (botaoLeitura.pressed() && !lerComando) {
lerComando = true;
digitalWrite(pinLed, HIGH);
} else if (botaoLeitura.pressed() && lerComando) {
lerComando = false;
digitalWrite(pinLed, LOW);
// LAÇO PARA LEITURA DO RECEPTOR IR QUANDO FOR PRESSIONADO O BOTÃO
while (lerComando) {
decode_results  results;
if (receptorIR.decode(&results)) {
  ircode   (&results);
  encoding (&results);
  dumpInfo (&results);
  dumpRaw  (&results);
  dumpCode (&results);
  receptorIR.resume();
  lerComando = false;
// BLOCO PARA RECEBER DADOS DA SERIAL E INICIAR EMISSOR IR
if (Serial.available()) {
char tecla = Serial.read();
switch (tecla) {
  case 'a':
    emissorIR.sendRaw(teclaA, sizeof(teclaA) / sizeof(teclaA[0]), frequencia);
    Serial.println("Enviando Tecla A clonada");
    delay(tempoTecla);
  case 'b':
    emissorIR.sendRaw(teclaB, sizeof(teclaB) / sizeof(teclaB[0]), frequencia);
    Serial.println("Enviando Tecla B clonada");
    delay(tempoTecla);
  case 'c':
    emissorIR.sendRaw(teclaC, sizeof(teclaC) / sizeof(teclaC[0]), frequencia);
    Serial.println("Enviando Tecla C clonada");
    delay(tempoTecla);
  case 'd':
    emissorIR.sendRaw(teclaD, sizeof(teclaD) / sizeof(teclaD[0]), frequencia);
    Serial.println("Enviando Tecla D clonada");
    delay(tempoTecla);
Siga as normas do forum.
Refaça seu tópico e coloque seu codigo entre tags.
Informe o link da biblioteca "PushButton.h", pois só encontrei a "PushButton.h"
com B de Button minúsculo.
