Mfrc 522 hangs with other near relay work!!!
Hello guys i have problem with rc522. I made rfid access control for my home elevator but rc522 after press d o buttom on elevator panel an switch relay was hangs. I tested board with separate power supply but still have problem. My code has sample access control in arduino software. I set watch doge but dont answer becuse rc 522 hangs
Don't you think we have to see that code to be able to help you?
Also post a wiring diagram of your complete setup!
I attach my code
F0R4L0PIO7GSDW5.ino (17.9 KB)
I used of 7805 for power supply to arduino pro mini and used of raw pin for supply. My board is pro mini 3.3v 8mhrz than for power supply rc 522 i used vcc pin on pro mini board.
That's not a wiring diagram. Post a diagram with all connections visible! It may be hand-drawn.
  do {
    successRead = getID(); 	// sets successRead to 1 when we get read from reader otherwise 0
    if (programMode) {
      cycleLeds();              // Program Mode cycles through RGB waiting to read a new card
    else {
      normalModeOn(); 		// Normal mode, blue Power LED is on, all others are off
  while (!successRead); 	//the program will not go further while you not get a successful read
That loop means that if you don't provide a valid card to the reader within 8s it will reset the Arduino.
Why do you need the watchdog?
