I am trying to read from an RFID tag using the DumpInfo example program from the MFRC522 library after replacing Serial with SerialUSB and (F("...")) with ("..."). It works fine. However, if I try to call
mfrc522.PICC_IsNewCardPresent()
and/or
mfrc522.PICC_DumpToSerial(&(mfrc522.uid))
from yield() I lose the USB connection, and I have to double click to reload the program.
So the question is does anyone have any success with using the MFCR522 library with an Arduino Zero and calling from yield()?
May be. the case. But I and others use delays often in Arduino. Also by using the yield() the USB handling is straight forward in a lot of Arduino Zero code found elsewhere.
