MFRC522 personal data write and read.
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN         9           // Configurable, see typical pin layout above
#define SS_PIN          10          // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance
  Serial.begin(9600);        // Initialize serial communications with the PC
  SPI.begin();               // Init SPI bus
  mfrc522.PCD_Init();        // Init MFRC522 card
  Serial.println(F("Write personal data on a MIFARE PICC "));
  // Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
  MFRC522::MIFARE_Key key;
  for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent()) {
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())    return;
  Serial.print(F("Card UID:"));    //Dump UID
  for (byte i = 0; i < mfrc522.uid.size; i++) {
    Serial.print(mfrc522.uid.uidByte[i], HEX);
  Serial.print(F(" PICC type: "));   // Dump PICC type
  MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
  Serial.println(mfrc522.PICC_GetTypeName(piccType));
  byte buffer[34];
  byte block;
  MFRC522::StatusCode status;
  byte size = sizeof(buffer);
  byte len;
  Serial.setTimeout(20000L) ;     // wait until 20 seconds for input from serial
  // Ask personal data: Family name
  Serial.println(F("Type Family name, ending with #"));
  len = Serial.readBytesUntil('#', (char *) buffer, 30) ; // read family name from serial
  for (byte i = len; i < 30; i++) buffer[i] = ' ';     // pad with spaces
  block = 1;
  //Serial.println(F("Authenticating using key A..."));
  status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &(mfrc522.uid));
  if (status != MFRC522::STATUS_OK) {
    Serial.print(F("PCD_Authenticate() failed: "));
    Serial.println(mfrc522.GetStatusCodeName(status));
    return;
  else Serial.println(F("PCD_Authenticate() success: "));
  // Write block
  status = mfrc522.MIFARE_Write(block, buffer, 16);
    Serial.print(F("MIFARE_Write() failed: "));
    return;
  else Serial.println(F("MIFARE_Write() success: "));
  block = 2;
    return;
  // Write block
  status = mfrc522.MIFARE_Write(block, &buffer[16], 16);
    return;
  block = 1;
  Serial.print(F("Reading data from block "));
  Serial.print(block);
  Serial.println(F(" ..."));
  status = (MFRC522::StatusCode) mfrc522.MIFARE_Read(block, buffer, &size);
    Serial.print(F("MIFARE_Read() failed: "));
  Serial.print(F("Data in block ")); Serial.print(block); Serial.println(F(":"));
  dump_byte_array(buffer, 16); Serial.println();
  // Ask personal data: First name
  Serial.println(F("Type First name, ending with #"));
  len = Serial.readBytesUntil('#', (char *) buffer, 20) ; // read first name from serial
  for (byte i = len; i < 20; i++) buffer[i] = ' ';     // pad with spaces
  block = 4;
    return;
  // Write block
    return;
  block = 5;
    return;
  // Write block
    return;
  Serial.println(" ");
  mfrc522.PICC_HaltA(); // Halt PICC
  mfrc522.PCD_StopCrypto1();  // Stop encryption on PCD
void dump_byte_array(byte *buffer, byte bufferSize)
  int i,j;
  char bytearray[bufferSize];
  for (byte i = 0; i < bufferSize; i++) {
    Serial.print(buffer[i] < 0x10 ? " 0" : " ");
    Serial.print(buffer[i]);
 strcpy((char*)bytearray , *buffer);
String myString[bufferSize] = String((char *)bytearray);
for(j=0;j<=bufferSize;j++)
Serial.println(myString[i]);
if(myString[i]==32)
I tried this code to read and write the personal data simultaneously onto the rfid card.
But i have a problem that i could write the data into rfid card but while extracting the data i am getting the unwanted data too on the serial monitor.
I have attached the screen shoot of the output.
