MFRC522 PICC_ReadCardSerial() does not work.
I need to read the UID of a card. Make some measurements and then send the data to my receiver.
When i use the code just to read data , my project works perfectly. When i add the part of the code that is responsible for the data transmission it enters always the if(!mfrc522.PICC_ReadCardSerial()). It's the same code. What is wrong. I've tested it on different arduinos and PCs.
Code without Transmission
#include <SPI.h>
#include <MFRC522.h>
#include <HX711.h>
#define SS_PIN 10
#define RST_PIN 9
#define calibration_factor -7050.0 //This value is obtained using the SparkFun_HX711_Calibration sketch
#define DOUT  3
#define CLK  2
MFRC522 mfrc522(SS_PIN, RST_PIN);                     // Create MFRC522 instance.
HX711 scale(DOUT, CLK);
int counter;
float weight;
  Serial.begin(9600);                                 // Initiate a serial communication
  SPI.begin();                                        // Initiate  SPI bus
  Serial.println("SPI initiated");
  mfrc522.PCD_Init();                                 // Initiate MFRC522
  Serial.println("MFRC22 initiated");
  scale.set_scale(calibration_factor);                //This value is obtained by using the SparkFun_HX711_Calibration sketch
  scale.tare();                                       //Assuming there is no weight on the scale at start up, reset the scale to 0
  Serial.println("Weight Cell Initiated");
  // Look for new cards
  if ( !mfrc522.PICC_IsNewCardPresent())
    return;
  // Select one of the cards
  if ( !mfrc522.PICC_ReadCardSerial())
    return;
  else{
    Serial.print("UID tag :");
    String content= "";
    byte letter;
    for (byte i = 0; i < mfrc522.uid.size; i++)
       //Show UID on serial monitor
       //Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
       //Serial.print(mfrc522.uid.uidByte[i], HEX);
       //Read UID on serial monitor
       content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
       content.concat(String(mfrc522.uid.uidByte[i], HEX));
    content.toUpperCase();
    if (content.substring(1) == "B0 09 BA 28"){
      Serial.print("New Chicken:");
      for (byte i = 0; i < mfrc522.uid.size; i++){
      counter = 0;
      weight = 0;
      while(scale.get_units()*0.453592 > 0.2){
        weight = weight + scale.get_units()*0.453592;
        counter++;
      weight = weight / counter;
      Serial.print("Chicken weights : ");
      Serial.println(weight);
      if( scale.get_units()*0.453592 > 0.1){
        //send info
        Serial.println("New Egg");
    else{
      Serial.println("No registered Chicken");
Code with Transmission
#include <SPI.h>
#include <HX711.h>
#include <RF22.h>
#include <RF22Router.h>
#define SS_PIN 10
#define RST_PIN 9
#define DOUT  3
#define CLK  2
#define SOURCE_ADDRESS 4
#define DESTINATION_ADDRESS 26
HX711 scale(DOUT, CLK);                               // Create scale instance
RF22Router rf22(SOURCE_ADDRESS);                      // Create RF22 instance
char data_read[RF22_ROUTER_MAX_MESSAGE_LEN]; // Allocate some space for the string
uint8_t data_send[RF22_ROUTER_MAX_MESSAGE_LEN];
int successful_transmissions=0;
int failed_transmissions=0;
int counter;
float weight;
uint8_t rssi;
float Pr = -90;
float throughput = 0;
String content= "";
 if (!rf22.init())                                    //Initiate RF22
    Serial.println("RF22 init failed");
  if (!rf22.setFrequency(440.0))
    Serial.println("setFrequency Fail");
  rf22.setTxPower(RF22_TXPOW_20DBM);
  rf22.setModemConfig(RF22::GFSK_Rb125Fd125);
  rf22.addRouteTo(DESTINATION_ADDRESS, DESTINATION_ADDRESS);
  Serial.print("Setup is Completed");
  if ( !mfrc522.PICC_IsNewCardPresent()){               // Look for new cards
    return;
  else{
    delay(100);
  if ( !mfrc522.PICC_ReadCardSerial()){                // Select one of the cards
      return;
  else{
    //Read UID
    content= "";
      printUID(mfrc522);
      counter = 0;
      weight = 0;
      while(mfrc522.PICC_ReadCardSerial()){
        counter++;
      Serial.print("weight:");
      //If there is an egg
      if(scale.get_units()*0.453592 > 0.1){
        sendData(content, &weight);
void printUID(MFRC522 mfrc522){
void sendData(String content, float *weight){
        memset(data_read, '\0', RF22_ROUTER_MAX_MESSAGE_LEN);
        memset(data_send, '\0', RF22_ROUTER_MAX_MESSAGE_LEN);
        sprintf(data_read, "NEWEGG %s %f", content.c_str(), *weight);
        data_read[RF22_ROUTER_MAX_MESSAGE_LEN - 1] = '\0';
        memcpy(data_send, data_read, RF22_ROUTER_MAX_MESSAGE_LEN);
        while(rf22.sendtoWait(data_send, sizeof(data_send), DESTINATION_ADDRESS) != RF22_ROUTER_ERROR_NONE){
          Serial.println("sendtoWait failed");
          failed_transmissions=failed_transmissions+1;
        Serial.println("sendtoWait SUCCESS");
        successful_transmissions=successful_transmissions+1;
        rssi = rf22.rssiRead();
        Pr = ((float)rssi - 230.0) / 1.8;
I'm sorry for uploading the whole code. I just wanted to show that there is no difference as far as the PICC_ReadCardSerial() and i don't know what goes wrong when i add the transmitting section.
