MG811 CO2 Sensor
Is there any code to arduino in order to read from the MG811 CO2 Sensor?
Google will no doubt tell you if there is...
I didn’t find anything on google.
Well there probably isn't then :P
Everywhere I know of that would have code like that would show up on google.
Hi! at the end do you know now the cod for co2 sensor? thanks, I must use, too ::)
@aranciagrossa Q1: Do you have a link to a datasheet? Q2: Do you have experience with Arduino projects? or uProc in general? Q3: what is your goal you want to achieve? Q4: The supplier of the device, does it have examples on his website? (assuming she has one)
update A1: http://www.parallax.com/Portals/0/Downloads/docs/prod/sens/MG811Datasheet.pdf Seems it need some signal boosting to provide a voltage Arduino will handle properly. Furthermore You need a quite stable 6Volt for the heating unit.
at http://www.alibaba.com/product-gs/285433549/MG811_CO2_gas_sensor.html you can mail the supplier
Some hardware diagrams http://www.picbasic.co.uk/forum/showthread.php?t=8709
