Hi.
Is here any chance for get working MgsModbus libraries on Opta RS485 ? On Mega board with Ethernet Shield V2 all works OK (I use this library because of connecting multiple TCP Masters to that TCP Slave Arduino).
I can compile code on Opta 485 but I cannot connect to Modbus.
Library is from link below -
I using slave example.
Or is here any other libraries with support for etc 5 active TCP clients in one time connected to that arduino tcp modbus slave ?? Standart ArduinoModbus allows only for one connection in time only - if I modify code for multiple clients - I can get works 3 connected client at once but if any client disconnect in "bad way" then after some time can only one TCP master connect to that device.
Thanks for help !
