Mh-z16 problem esp 32
I am working on a project with a CO 2 sensor (MH-Z16) and I am using the ESP32 module. After several tries I still can't get it to work. The monitor sends me values like: 128 144 31 251 63 152 1 252 63 . I still don't understand why, please help me. I am using this code And the result is
resultat capteur mh z16
  This test code is write for Arduino AVR Series(UNO, Leonardo, Mega)
  If you want to use with LinkIt ONE, please connect the module to D0/1 and modify:
  // #include <SoftwareSerial.h>
  // SoftwareSerial s_serial(2, 3);      // TX, RX
  #define sensor Serial1
SoftwareSerial s_serial(17, 16);      // TX, RX
#define sensor s_serial
const unsigned char cmd_get_sensor[] =
    0xff, 0x01, 0x86, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x79
unsigned char dataRevice[9];
int temperature;
int CO2PPM;
    sensor.begin(9600);
    Serial.println("get a 'g', begin to read from sensor!");
    Serial.println("********************************************************");
    if(dataRecieve())
        Serial.print("Temperature: ");
        Serial.print(temperature);
        Serial.print("  CO2: ");
        Serial.print(CO2PPM);
        Serial.println("");
bool dataRecieve(void)
    byte data[9];
    int i = 0;
    //transmit command data
    for(i=0; i<sizeof(cmd_get_sensor); i++)
        sensor.write(cmd_get_sensor[i]);
    delay(10);
    //begin reveiceing data
    if(sensor.available())
        while(sensor.available())
            for(int i=0;i<9; i++)
                data[i] = sensor.read();
    for(int j=0; j<9; j++)
        Serial.print(data[j]);
        Serial.print(" ");
    Serial.println("");
    if((i != 9) || (1 + (0xFF ^ (byte)(data[1] + data[2] + data[3] + data[4] + data[5] + data[6] + data[7]))) != data[8])
        return false;
    CO2PPM = (int)data[2] * 256 + (int)data[3];
    temperature = (int)data[4] - 40;
    return true;
I'm curious as to why are you using software serial with an esp32 when an esp32 has several hardware serial ports?
In global I declare the hardware serial port #include <HardwareSerial.h> and //serial(2) = pin25 RX, pin26 TX HardwareSerial co2Serial ( 2 );
In setup() the declared hardware serial port is initialized.
co2Serial.begin( 9600 , SERIAL_8N1, 25, 26 ); // pin25 RX, pin26 TX
I have a project school and my teacher said i need to do with an ESP 32 , i will try monday if it work for me and thank you for your answer .
Hello again please i can have the whole code this can really help me thank you
