MH-Z19B gets negative value
Hi, I'm having difficulties using the MH-Z19B with my arduino nano.
I connected Vin to 5V , Gnd to Gnd, RX to D2 and TX to D3 ( I already tried switching them) and PWM to D13. There is my code, it's the example from the MHZ library :
#include <SoftwareSerial.h>
#include <MHZ.h>
// pin for pwm reading
#define CO2_IN 13
// pin for uart reading
#define MH_Z19_RX 2
#define MH_Z19_TX 3
MHZ co2(MH_Z19_RX, MH_Z19_TX, CO2_IN, MHZ19B);
 pinMode(CO2_IN, INPUT);
 delay(100);
 Serial.println("MHZ 19B");
 // enable debug to get addition information
 // co2.setDebug(true);
 if (co2.isPreHeating()) {
   Serial.print("Preheating");
   while (co2.isPreHeating()) {
     Serial.print(".");
     delay(5000);
 Serial.print("\n----- Time from start: ");
 Serial.print(millis() / 1000);
 Serial.println(" s");
 int ppm_uart = co2.readCO2UART();
 Serial.print("PPMuart: ");
 if (ppm_uart > 0) {
   Serial.print(ppm_uart);
   Serial.print("n/a");
 int ppm_pwm = co2.readCO2PWM();
 Serial.print(", PPMpwm: ");
 Serial.print(ppm_pwm);
 int temperature = co2.getLastTemperature();
 Serial.print(", Temperature: ");
 if (temperature > 0) {
   Serial.println(temperature);
   Serial.println("n/a");
 Serial.println("\n------------------------------");
 delay(5000);
I get this message :
----- Time from start: 180 s
PPMuart: n/aUnable to read value. Timeout.
Can someone explain me what I got wrong ?
As pin 13, (#define CO2_IN 13), has a resistor and an LED for gnd, it may affect the reading of your sensor device.
Try using another pin and report the result.
Thanks for your response, I tried with pin 8 but I get the same result.
