MHz Speed Analog Reading + High Quality 40kHz Square Wave
Are you using the right wavelength for the right job? Sound waves at that frequency have wavelengths of 1cm, that limits your accuracy. Why don't you use interferometry? It measures about .1um? Is absolute distance important to you or is just the relative distance change important? What exactly is your length scale that you want 0.1mm or better resolution with?
