Mi PC doesn't recognize my board
Two weeks ago I bought two arduinos pro micro in amazon. This ones TECNOIOT 2pcs Pro Micro ATmega32U4 5V/16MHz Module with Pin Head : Amazon.es: Industrial & Scientific.
But when I downloaded the IDE it didn't let me to put the code in them. I searched a bit and I discovered that the problem was that mi PC don't reecognize them. I try lots of cables or changing the ports, but it didn't work. I searched a lot, and all the people download drivers, or at least their device manager warn them that was a strange hardware. Not in my case, it doesn't have COM's port actived and the recognize of board is imposible.
Searching for similar problems in forums i found a post were it said that it could be this three things:
You say "device manager", so I assume you're using Windows. If you open Device Manager and then connect your Pro Micro to your computer using the USB cable, do you see a new device appear in the device tree? You should see the device tree disappear and reappear as it is refreshed when a new device is added.
