Micro SD-CARD Reader wont initialize on Arduino MEGA-2560
Hey I have a problem.
Im doing a school project with the Arduino mega 2560 and a Micro-SD card reader (the Reader: MissBirdler B01N40RKIL The SD-Card Reader)
Also i am using a 64 GB Micro-SD card formatted to FAT-32. Its a Samsung 64GB EVO PLUS Micro-SDXC U3.
My pin Layout is like this: SPI: 50 (MISO), 51 (MOSI), 52 (SCK), 53 (CS). VCC and Ground is self explanatory.
My Error Message is this: Initializing SD-Card… Initialization failed
I used this example Programm for testing:
// Arduino SD Card Tutorial v1.00 //
// Get the latest version of the code here: //
// http://educ8s.tv/arduino-sd-card-tutorial //
#include <SD.h>
#include <SPI.h>
int CS_PIN = 53;
File file;
initializeSD();
createFile(“test.txt”);
writeToFile(“This is sample text!”);
closeFile();
openFile(“prefs.txt”);
Serial.println(readLine());
closeFile();
void initializeSD()
Serial.println(“Initializing SD card…”);
pinMode(CS_PIN, OUTPUT);
if (SD.begin())
Serial.println(“SD card is ready to use.”);
} else
Serial.println(“SD card initialization failed”);
return;
int createFile(char filename)
file = SD.open(filename, FILE_WRITE);
if (file)
Serial.println(“File created successfully.”);
return 1;
} else
Serial.println(“Error while creating file.”);
return 0;
int writeToFile(char text)
if (file)
file.println(text);
Serial.println("Writing to file: ");
Serial.println(text);
return 1;
} else
Serial.println(“Couldn’t write to file”);
return 0;
void closeFile()
if (file)
file.close();
Serial.println(“File closed”);
int openFile(char filename)
file = SD.open(filename);
if (file)
Serial.println(“File opened with success!”);
return 1;
} else
Serial.println(“Error opening file…”);
return 0;
String readLine()
String received = “”;
char ch;
while (file.available())
ch = file.read();
if (ch == ‘\n’)
return String(received);
received += ch;
return “”;
Unless things have changed, the SD.h library doesn't support SDXC cards. There may be an Adafruit library that does, or you might try this one:
I don't know whether U3 messes things up.
