micro SD "HC class 4" card
Hi all,
Has anyone test the SD card reader that comes included with the Ethernet Shield, in combination with one of those "HC class 4" micro SD cards?
Thanks.
Here are the results for a Class 4 Kingston 4GB HC card with the Ethernet shield on an UNO.
http://www.amazon.com/Kingston-microSDHC-Memory-SDC4-4GBET/dp/B00200K1TI
For SdInfo:
init time: 990 ms
Card type: SDHC
Manufacturer ID: 0X41
OEM ID: 42
Product: SD4GB
Version: 2.0
Serial number: 2711490139
Manufacturing date: 3/2009
cardSize: 7745536 (512 byte blocks)
flashEraseSize: 128 blocks
eraseSingleBlock: true
SD Partition Table
part,boot,type,start,length
1,0X0,0XB,8192,7737344
2,0X0,0X0,0,0
3,0X0,0X0,0,0
4,0X0,0X0,0,0
Volume is FAT32
blocksPerCluster: 64
clusterCount: 120768
freeClusters: 120539
fatStartBlock: 14496
fatCount: 2
blocksPerFat: 944
rootDirStart: 2
dataStartBlock: 16384
Here is the SdFat bench result (Note write is very slow):
Type is FAT32
File size 5MB
Buffer size 100 bytes
Starting write test. Please wait up to a minute
Write 65.34 KB/sec
Maximum latency: 234516 usec, Minimum Latency: 84 usec, Avg Latency: 1521 usec
Starting read test. Please wait up to a minute
Read 278.91 KB/sec
Maximum latency: 3588 usec, Minimum Latency: 80 usec, Avg Latency: 353 usec
Here are the bench results for a Class 10 Amazon 4GB card Amazon.com
Type is FAT32
File size 5MB
Write 169.04 KB/sec
Maximum latency: 189888 usec, Minimum Latency: 84 usec, Avg Latency: 586 usec
Read 288.37 KB/sec
Maximum latency: 3136 usec, Minimum Latency: 80 usec, Avg Latency: 341 usec
Thanks! Then I guess I will go for the 8GB Kingston Class 4 micro SD HC + SD adapter.
I was kind of afraid that the "new/modern" micro SD may not be compatible with the Ethernet Shield's card reader.
