Micro SD problem
Hi, I'm developing a watch and I'm trying to load images from a micro sd, but it gives me the following error:
Show your proof.
Here is the original sketch, deleted by OP...
#include <Arduino.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ST7789.h>
#include <SPI.h>
#include <SD.h>
#include <Fonts/FreeSansBold18pt7b.h>
#include <Wire.h>
#include <WiFi.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
#include <TimeLib.h>
#include <cst816t.h>
#define TFT_CS_LCD        9
#define TFT_RST_LCD       8
#define TFT_DC_LCD        10
#define TFT_MOSI_LCD      3
#define TFT_SCLK_LCD      46
#define SCK_MIC_SD        4
#define MISO_MIC_SD       17
#define MOSI_MIC_SD       11
#define CS_MIC_SD         18
String wifiIcon = "";
String btIcon = "";
String cuoreIcon = "";
String stepIcon = "";
#define TP_SCL  16
#define TP_SDA  15
#define TP_RST 7    // Pin di reset
#define TP_IRQ 6    // Pin di interrupt
#define TP_ADDR 0x15
#define TP532 0x24
#define MPU6050 0x68
#define MAX30102 0x57
const char* ssid = "";
const char* password = "";
int16_t lastY = -1;
// Variables to store the last date and time values
int lastYear = 0;
int lastMonth = 0;
int lastDay = 0;
int lastHour = 0;
int lastMinute = 0;
const float referenceVoltage = 3.3;
const float resistorDivider = 2.0;
#define batteryPin 5
int ultimo_aggiornamento = -20000;
bool microsd = false;
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "pool.ntp.org", 7200, 60000);
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS_LCD, TFT_DC_LCD, TFT_MOSI_LCD, TFT_SCLK_LCD, TFT_RST_LCD);
TwoWire Wire2 = TwoWire(1);  // 1 è il bus I2C secondario
cst816t touchpad(Wire2, TP_RST, TP_IRQ);
int pagina_utente = 0; //home page = 0, settings = 1
void disegna_icona(String iconData, int x_start, int y_start, int width, int height, uint16_t color) {
  for (int row = 0; row < height; row++) {
    for (int col = 0; col < width; col++) {
      int index = row * width + col;
      if (index >= iconData.length()) continue;
      char pixel = iconData.charAt(index);
      if (pixel == '1') {
        tft.drawPixel(x_start + col, y_start + row, ST77XX_BLACK);
        tft.drawPixel(x_start + col, y_start + row, color);
String readImageFile(const char* filename) {
  String imageData = "";
  File file = SD.open(filename, FILE_READ);
  if (!file) {
    Serial.print("Errore nell'aprire il file ");
    Serial.println(filename);
    return "";
  while (file.available()) {
    char c = file.read();
    if (c == '0' || c == '1') {
      imageData += c;
  file.close();
  Serial.print("File caricato: ");
  return imageData;
void stato_batteria() {
  int adcValue = analogRead(batteryPin); // Legge il valore ADC
  float voltage = adcValue * referenceVoltage / 4095.0 * resistorDivider; // Calcola la tensione della batteria
  // Calcola la percentuale di batteria (considerando 4.2V come 100% e 3V come 0%)
  int batteryPercentage = (voltage - 3) * 100.0 / (4.1 - 3);
  // Limita la percentuale tra 0 e 100%
  if (batteryPercentage > 100.0) batteryPercentage = 100.0;
  if (batteryPercentage < 0.0) batteryPercentage = 0.0;
  int larghezza = map(batteryPercentage, 0, 100, 0, 26);
  tft.fillRect(180, 13, 30, 20, ST77XX_WHITE);
  tft.fillRect(210, 18, 7, 12, ST77XX_WHITE);
  tft.fillRect(182, 15, 26, 16, ST77XX_BLACK);
  tft.fillRect(182, 15, larghezza, 16, ST77XX_GREEN);
  tft.setTextColor(ST77XX_WHITE);
  tft.setTextSize(2);
  if (batteryPercentage > 99) {
    tft.setCursor(130, 15);
  } else if (batteryPercentage < 10) {
    tft.setCursor(150, 15);
    tft.setCursor(135, 15);
  tft.fillRect(130, 15, 50, 20, ST77XX_BLACK);
  tft.print(batteryPercentage);
  tft.print("%");
void wifi(bool stato) {
  if (stato) {
    disegna_icona(wifiIcon, 20, 10, 24, 24, tft.color565(0, 191, 255));
    disegna_icona(wifiIcon, 20, 10, 24, 24, tft.color565(128, 128, 128));
void bluetooth(bool stato) {
  if (stato) {
    disegna_icona(btIcon, 50, 10, 16, 24, tft.color565(0, 191, 255));
    disegna_icona(btIcon, 50, 10, 16, 24, tft.color565(128, 128, 128));
void passi(int passi) {
  tft.setTextSize(2);
  if (passi > 9999) {
    tft.setCursor(35, 205);
  } else if (passi > 999) {
    tft.setCursor(42, 205);
  } else if (passi > 99) {
    tft.setCursor(47, 205);
    tft.setCursor(55, 205);
  tft.fillRect(35, 205, 80, 14, ST77XX_BLACK);
  tft.print(passi);
void data_ora() {
  int currentYear = year();
  int currentMonth = month();
  int currentDay = day();
  int currentHour = hour();
  int currentMinute = minute();
  if (currentYear != lastYear || currentMonth != lastMonth || currentDay != lastDay || currentHour != lastHour || currentMinute != lastMinute) {
    Serial.printf("Data e ora aggiornate: %02d:%02d %02d/%02d/%04d\n", currentHour, currentMinute, currentDay, currentMonth, currentYear);
    tft.fillRect(35, 70, 190, 100, ST77XX_BLACK);
    tft.setTextSize(2);
    tft.setFont(&FreeSansBold18pt7b);
    tft.setCursor(35, 120);
    String hourStr = currentHour < 10 ? "0" + String(currentHour) : String(currentHour);
    String minuteStr = currentMinute < 10 ? "0" + String(currentMinute) : String(currentMinute);
    tft.print(hourStr + ":" + minuteStr);
    tft.setTextSize(2);
    tft.setFont();
    tft.setCursor(60, 140);
    tft.print(currentDay < 10 ? "0" + String(currentDay) : String(currentDay));
    tft.print("/");
    tft.print(currentMonth < 10 ? "0" + String(currentMonth) : String(currentMonth));
    tft.print("/");
    tft.print(currentYear);
    lastYear = currentYear;
    lastMonth = currentMonth;
    lastDay = currentDay;
    lastHour = currentHour;
    lastMinute = currentMinute;
void Home_page() {
  tft.drawRoundRect(10, 8, 222, 30, 20, ST77XX_WHITE);
  tft.drawRoundRect(7, 180, 113, 90, 33, ST77XX_WHITE);
  tft.drawRoundRect(123, 180, 113, 90, 33, ST77XX_WHITE);
  if (microsd) {
      disegna_icona(stepIcon, 50, 226, 32, 40, ST77XX_WHITE);
      disegna_icona(cuoreIcon, 157, 210, 46, 40, ST77XX_RED);
      Serial.println("Errore: non è possibile caricare le icone dalla scheda SD.");
  wifi(1);
  bluetooth(1);
  passi(99999);
  if (millis() - ultimo_aggiornamento > 10 * 1000) {
    ultimo_aggiornamento = millis(); // Aggiorna il timestamp
    stato_batteria(); // Chiama la funzione desiderata
  data_ora();
void impostazioni() {
  tft.fillScreen(ST77XX_BLACK);
  tft.setTextSize(2);
  tft.print("Impostazioni");
  delay(2000);
  SD.begin(CS_MIC_SD, SPI, 1000000); // Usa 1 MHz (1000000 Hz)
  analogReadResolution(12);
  Wire2.begin(TP_SDA, TP_SCL);
  touchpad.begin(mode_touch);
  WiFi.begin(ssid, password);
  int retryCount = 0;
  bool wifiConnected = false;
  while (WiFi.status() != WL_CONNECTED && retryCount < 20) {
    Serial.print(".");
    retryCount++;
  if (WiFi.status() == WL_CONNECTED) {
    Serial.println("Connesso a Wi-Fi");
    timeClient.begin();
    timeClient.update();
    unsigned long epochTime = timeClient.getEpochTime();
    setTime(epochTime);
    int currentSecond = second();
    Serial.printf("Orario ricevuto: %02d:%02d:%02d %02d/%02d/%04d\n", currentHour, currentMinute, currentSecond, currentDay, currentMonth, currentYear);
    Serial.println("Connessione Wi-Fi fallita. Impostazione data/ora predefiniti.");
    setTime(0);
  digitalWrite(TFT_CS_LCD, HIGH);
  digitalWrite(CS_MIC_SD, LOW);
  SPI.begin(SCK_MIC_SD, MISO_MIC_SD, MOSI_MIC_SD, CS_MIC_SD);
  int retrySD = 0;
  while (!SD.begin(CS_MIC_SD) && retrySD < 5) {
      Serial.println("Errore nell'inizializzazione della scheda SD! Riprovo...");
      retrySD++;
  if (retrySD == 5) {
      Serial.println("Errore nell'inizializzazione della scheda SD! Verifica la connessione hardware.");
      microsd = false;
      microsd = true;
      if (!SD.exists("/wifi.txt") || !SD.exists("/bluetooth.txt") || !SD.exists("/cuore.txt") || !SD.exists("/step.txt")) {
        Serial.println("Errore: File richiesti non trovati sulla scheda SD!");
        microsd = false;
        Serial.println("Scheda SD inizializzata con successo.");
        wifiIcon = readImageFile("/wifi.txt");
        btIcon = readImageFile("/bluetooth.txt");
        cuoreIcon = readImageFile("/cuore.txt");
        stepIcon = readImageFile("/step.txt");
  digitalWrite(CS_MIC_SD, HIGH);
  digitalWrite(TFT_CS_LCD, LOW);
  tft.init(240, 280);
  tft.setRotation(2);
  Home_page();
  if (touchpad.available()) {
    tft.fillRect(0, 0, 240, 280, ST77XX_BLACK);
    switch (touchpad.gesture_id) {
      case GESTURE_NONE:
        Serial.print("NONE");
      case GESTURE_SWIPE_UP:
        Serial.print("SWIPE DOWN");
        Home_page();
      case GESTURE_SWIPE_DOWN:
        Serial.print("SWIPE UP");
        impostazioni();
      case GESTURE_SWIPE_LEFT:
        Serial.print("SWIPE LEFT");
      case GESTURE_SWIPE_RIGHT:
        Serial.print("SWIPE RIGHT");
      case GESTURE_SINGLE_CLICK:
        Serial.print("SINGLE CLICK");
      case GESTURE_DOUBLE_CLICK:
        Serial.print("DOUBLE CLICK");
      case GESTURE_LONG_PRESS:
        Serial.print("LONG PRESS");
      default:
        Serial.print("UNKNOWN ");
    // Stampa la posizione (x, y) e il numero di dita
    Serial.print("at (");
    Serial.print(touchpad.x);
    Serial.print(", ");
    Serial.print(touchpad.y);
    Serial.print(") fingers: ");
    Serial.println(touchpad.finger_num);
  delay(100); // Aggiungi un breve ritardo per evitare di sovraccaricare la seriale
with this script the micro sd is read correctly
#include <SPI.h>
#include <SD.h>
// Inizializzazione seriale
// Inizializzazione SPI
SPI.begin(11, 17, 4, 18); // SCK, MISO, MOSI, CS
// Inizializzazione della microSD
if (!SD.begin(18)) {
Serial.println("Errore nell'inizializzazione della microSD");
return;
Serial.println("MicroSD inizializzata con successo");
// Non serve codice nel loop per questo esempio
if the SD card is sharing a SPI bus with other devices there can be problems - see SD card reader sharing SPI bus
how have you connected the various devices to the ESP32?
upload a schematic?
followed by
is not the same as
