I have a Micro R3 and I am developing on Win10 64bit.
The Micro was working just fine as I was developing my project but it stopped accepting sketches over the USB a couple of days ago.
I am able to burn the bootloader and upload sketches using ICSP interface and an UNO.
IDE is 1.6.7
I was using 1.7.8 but that's weird. I'm sure I got it from Arduino on 21 Jan 2016. Install file is called arduino-1.7.8.org-windows.exe.
I updated FTDI drivers.
Loopback test fails. The board is never seen when reset is grounded.
I can use the serial monitor to input and output over the USB if the sketch uses it.
Just a regular upload looks like this:
Sketch uses 4,496 bytes (15%) of program storage space. Maximum is 28,672 bytes.
Global variables use 148 bytes (5%) of dynamic memory, leaving 2,412 bytes for local variables. Maximum is 2,560 bytes.
Forcing reset using 1200bps open/close on port COM10
PORTS {COM1, COM10, } / {COM1, } => {}
PORTS {COM1, } / {COM1, } => {}
Couldn't find a Board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
If I do the timing of pressing the reset after upload I get this:
PORTS {COM1, } / {COM1, COM10, } => {COM10, }
Found upload port: COM10
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM10 -b57600 -D -Uflash:w:C:\Users\Adam\AppData\Local\Temp\buildfc0c6aaff670348eaa8d34dfc5965725.tmp/Blink2.ino.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM10
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I have tried to load OptiBoot and it fails with this Java error:
java.lang.NullPointerException
at cc.arduino.packages.uploaders.SerialUploader.burnBootloader(SerialUploader.java:314)
at processing.app.Editor.lambda$handleBurnBootloader$42(Editor.java:2754)
at java.lang.Thread.run(Thread.java:745)
Error while burning bootloader.
I tried to load the MightyCore bootloader and (after changing the board ID) was able to get it to load but then the Pin13 LED dims and the Micro never shows up when connected to USB. It won't do anything until I put the basic bootloader back.
