I have some code that isnt too long but has considerable length. The code works fine & uploads without an issue on my uno but my micro is disconnecting while i am uploading this script. When i upload a small sketch like fading it does the fading script & after a couple of seconds its stops the fading. Any ideas?
Edit: I sent this exact same code to the uno and the code ran correctly. This time the arduino micro appeared on COM7. While completing it went to COM6 and then back to COM7 without running the code correctly. When the Arduino micro switched from COM7 to COM8 three lights were on the built in led (PIN13) and the RX & TX lights.
Code here:
//included libraries
#include "SPI.h" //Includes library for SPI communication of display
#include "Adafruit_GFX.h" //Includes core graphics library
#include "Adafruit_SSD1351.h" //Includes hardware specific library
extern const uint16_t WhiteSquare[];
extern const uint16_t LBlock_R1[];
extern const uint16_t thumbsup48[];
//screen dimensions
#define SCREEN_WIDTH 128 //pixel width
#define SCREEN_HEIGHT 128 //pixel height
//pin definitions
#define SCLK_PIN 13 //defines s clock pin
#define MOSI_PIN 11 //defines master-out slave-in SDA pin
#define RST_PIN 3 //defines reset pin
#define DC_PIN 5 //defines master-in slave-out pin
#define CS_PIN 4 //defines chip select pin
// Colour definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define GREY 0x8410
#define ORANGE 0xE880
Adafruit_SSD1351 display = Adafruit_SSD1351(SCREEN_WIDTH, SCREEN_HEIGHT, &SPI, CS_PIN, DC_PIN, RST_PIN);
display.begin();
display.fillScreen(BLACK);
display.setTextSize(3);
display.drawRGBBitmap(30,30,thumbsup48,48,48);
//display.drawRGBBitmap(0,0,LBlock_R1,3,3);
display.setCursor(1, 1);
display.setTextColor(WHITE);
//display.print(1234);
delay(100);
for (int x = 1; x<128; x+=3) {
for (int y= 1; y<128; y+=3){
draw3x3(x,y);
delay(10);
//delay(1000);
void draw3x3(int x, int y) {
for (int xA = x-2; xA<x+2; xA++){
for (int yA = y-2; yA<y+2; yA++ ){
display.drawPixel(xA,yA,WHITE);
Second page of code:
// Generated by : ImageConverter 565 Online
// Generated from : Black 3x3.png
// Time generated : Tue, 26 Dec 23 03:55:45 +0100 (Server timezone: CET)
// Image Size : 3x3 pixels
// Memory usage : 18 bytes
#if defined(__AVR__)
#include <avr/pgmspace.h>
#elif defined(__PIC32MX__)
#define PROGMEM
#elif defined(__arm__)
#define PROGMEM
#endif
const unsigned short WhiteSquare[9] PROGMEM={
0xFFFF, 0xFFFF, 0xFFFF,
const unsigned short LBlock_R1[9] PROGMEM={
0x0000, 0xFFFF, 0xFFFF,
0x0000, 0x0000, 0xFFFF,
const unsigned short thumbsup48[2304] PROGMEM={
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0010 (16) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0020 (32) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0030 (48) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0040 (64) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0050 (80) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0060 (96) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0070 (112) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0080 (128) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0090 (144) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x00A0 (160) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x00B0 (176) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x00C0 (192) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x00D0 (208) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF5A3, 0xF582, 0x0000, 0x0000, 0x0000, 0x0000, // 0x00E0 (224) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x00F0 (240) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0100 (256) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF5E2, 0xF5C3, 0xF5C3, 0xF5A2, 0xFDA4, 0x0000, 0x0000, // 0x0110 (272) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0120 (288) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0130 (304) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE03, 0xFE03, 0xF5E3, 0xF5C3, 0xF5A2, 0x0000, 0x0000, // 0x0140 (320) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0150 (336) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0160 (352) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE44, 0xFE23, 0xFE03, 0xF603, 0xF5E3, 0xFBE0, 0x0000, // 0x0170 (368) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0180 (384) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0190 (400) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFDE7, 0xFE44, 0xFE44, 0xFE24, 0xFE23, 0xFE03, 0xFE03, 0x0000, // 0x01A0 (416) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x01B0 (432) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x01C0 (448) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE64, 0xFE64, 0xFE64, 0xFE64, 0xFE44, 0xFE23, 0xFE03, 0x0000, // 0x01D0 (464) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x01E0 (480) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x01F0 (496) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFFE0, 0xFE84, 0xFE84, 0xFE64, 0xFE64, 0xFE64, 0xFE44, 0xFE24, 0x0000, // 0x0200 (512) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0210 (528) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0220 (544) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE85, 0xFE85, 0xFE84, 0xFE84, 0xFE84, 0xFE64, 0xFE64, 0xFE44, 0x0000, // 0x0230 (560) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0240 (576) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0250 (592) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE86, 0xFE86, 0xFEA5, 0xFE85, 0xFE84, 0xFE84, 0xFE84, 0xFE64, 0xFE44, 0x0000, // 0x0260 (608) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0270 (624) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0280 (640) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0xFE66, 0xFEA7, 0xFEA7, 0xFEA6, 0xFEA6, 0xFEA5, 0xFE85, 0xFE85, 0xFE84, 0xFE64, 0xFDE3, 0x0000, // 0x0290 (656) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x02A0 (672) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x02B0 (688) pixels
0x0000, 0x0000, 0x0000, 0xFEA8, 0xFEA8, 0xFEA8, 0xFEA7, 0xFEA7, 0xFEA6, 0xFEA6, 0xFEA5, 0xFE85, 0xFE84, 0xFE84, 0x0000, 0x0000, // 0x02C0 (704) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x02D0 (720) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x02E0 (736) pixels
0x0000, 0xFFEA, 0xFEC9, 0xFEC9, 0xFEC8, 0xFEC8, 0xFEC8, 0xFEA7, 0xFEA7, 0xFEA6, 0xFEA6, 0xFEA5, 0xFE85, 0xFE84, 0x0000, 0x0000, // 0x02F0 (752) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0300 (768) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0310 (784) pixels
0xFECA, 0xFECA, 0xFECA, 0xFEC9, 0xFEC9, 0xFEC9, 0xFEC8, 0xFEC8, 0xFEA7, 0xFEA7, 0xFEA6, 0xFEA6, 0xFE85, 0xFE84, 0x0000, 0x0000, // 0x0320 (800) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0330 (816) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFEEA, // 0x0340 (832) pixels
0xFECA, 0xFEEA, 0xFEEA, 0xFEEA, 0xFECA, 0xFEC9, 0xFEC9, 0xFEC8, 0xFEC8, 0xFEA7, 0xFEA7, 0xFEA6, 0xFE85, 0x0000, 0x0000, 0x0000, // 0x0350 (848) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0360 (864) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFEEA, 0xFEEB, // 0x0370 (880) pixels
0xFEEB, 0xFEEB, 0xFEEB, 0xFEEB, 0xFEEA, 0xFECA, 0xFEC9, 0xFEC9, 0xFEC8, 0xFEA8, 0xFEA7, 0xFEA6, 0xFEA6, 0xFE66, 0x0000, 0x0000, // 0x0380 (896) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0390 (912) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE8B, 0xFEEA, 0xFEEB, 0xFEEB, // 0x03A0 (928) pixels
0xFEEC, 0xFEEC, 0xFEEC, 0xFEEB, 0xFEEB, 0xFECA, 0xFECA, 0xFEC9, 0xFEC8, 0xFEA8, 0xFEA7, 0xFEA7, 0xFEA6, 0xFE65, 0xFE44, 0xFE44, // 0x03B0 (944) pixels
0xFE24, 0xF5C3, 0xEDA3, 0xED63, 0xED63, 0xED63, 0xF5A3, 0xF5C3, 0xF5A2, 0xFFE0, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x03C0 (960) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF626, 0xFE46, 0xFEA7, 0xFEC8, 0xFEC9, 0xFEC9, 0xFEEA, 0xFEEB, 0xFEEB, 0xFEEC, // 0x03D0 (976) pixels
0xFEEC, 0xFF0D, 0xFEEC, 0xFF0C, 0xFEEC, 0xFEEB, 0xFEEA, 0xFEC9, 0xFEC9, 0xFEA8, 0xFEA7, 0xFE66, 0xF625, 0xF5A4, 0xED63, 0xED43, // 0x03E0 (992) pixels
0xF583, 0xF5E4, 0xFE24, 0xFE85, 0xFE85, 0xFE85, 0xFE84, 0xFE64, 0xFE24, 0xF5E3, 0xFCE3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x03F0 (1008) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE45, 0xFE25, 0xFE46, 0xFE87, 0xFEA8, 0xFEC9, 0xFECA, 0xFEEA, 0xFEEB, 0xFEEB, 0xFF0C, // 0x0400 (1024) pixels
0xFF0D, 0xFF0D, 0xFF0D, 0xFF0D, 0xFF0C, 0xFEEB, 0xFECA, 0xFEC9, 0xFEC9, 0xFEA8, 0xFE67, 0xF605, 0xF5A4, 0xED23, 0xED63, 0xFE44, // 0x0410 (1040) pixels
0xFE84, 0xFEA6, 0xFEA8, 0xFEC9, 0xFEC9, 0xFEC9, 0xFEC7, 0xFEA5, 0xFE84, 0xFE24, 0xF5C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0420 (1056) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF625, 0xFE45, 0xFE46, 0xFE87, 0xFEA8, 0xFEC9, 0xFEC9, 0xFEEA, 0xFEEB, 0xFEEC, 0xFF0C, // 0x0430 (1072) pixels
0xFF0D, 0xFF0D, 0xFF0D, 0xFF0D, 0xFF0C, 0xFEEC, 0xFEEA, 0xFEC9, 0xFEA8, 0xFE87, 0xFE46, 0xF5E5, 0xED64, 0xED23, 0xFE04, 0xFE84, // 0x0440 (1088) pixels
0xFEA7, 0xFEC9, 0xFEEB, 0xFEEC, 0xFEEC, 0xFEEC, 0xFEEA, 0xFEC8, 0xFEA6, 0xFE64, 0xF5E3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0450 (1104) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF624, 0xFE45, 0xFE46, 0xFE87, 0xFEA8, 0xFEC9, 0xFEC9, 0xFECA, 0xFEEB, 0xFEEC, 0xFF0D, // 0x0460 (1120) pixels
0xFF0D, 0xFF0D, 0xFF0D, 0xFF0D, 0xFEEC, 0xFEEB, 0xFEEA, 0xFEC9, 0xFEA8, 0xFE87, 0xFE46, 0xF5C4, 0xED44, 0xED23, 0xFE44, 0xFE85, // 0x0470 (1136) pixels
0xFEA8, 0xFECA, 0xFEEC, 0xFF0D, 0xFF0D, 0xFEEC, 0xFEEB, 0xFEC9, 0xFEA6, 0xFE64, 0xF5E3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0480 (1152) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE24, 0xFE45, 0xFE46, 0xFE86, 0xFEC8, 0xFEC8, 0xFEC9, 0xFECA, 0xFEEB, 0xFEEC, 0xFF0D, // 0x0490 (1168) pixels
0xFF0D, 0xFF0D, 0xFF0D, 0xFF0C, 0xFEEC, 0xFEEB, 0xFEC9, 0xFEA8, 0xFE87, 0xFE87, 0xFE26, 0xF5C4, 0xED64, 0xED23, 0xFE23, 0xFE84, // 0x04A0 (1184) pixels
0xFEA6, 0xFEC8, 0xFEEA, 0xFEEB, 0xFEEB, 0xFEEA, 0xFEC9, 0xFEA7, 0xFE85, 0xFE44, 0xF5C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x04B0 (1200) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE24, 0xFE45, 0xFE45, 0xFE86, 0xFEA7, 0xFEC8, 0xFEC9, 0xFEC9, 0xFEEB, 0xFEEC, 0xFEEC, // 0x04C0 (1216) pixels
0xFEEC, 0xFEED, 0xFF0D, 0xFEEC, 0xFEEB, 0xFEC9, 0xFEC9, 0xFE67, 0xFE87, 0xFE87, 0xFE46, 0xF5E5, 0xED64, 0xED23, 0xED83, 0xFE64, // 0x04D0 (1232) pixels
0xFE84, 0xFEA5, 0xFEA6, 0xFEA7, 0xFEA7, 0xFEA6, 0xFE85, 0xFE84, 0xFE44, 0xF5E3, 0xF562, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x04E0 (1248) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE24, 0xFE45, 0xFE45, 0xFE86, 0xFEA7, 0xFEC8, 0xFEC8, 0xFEC9, 0xFEEA, 0xFEEB, 0xFEEC, // 0x04F0 (1264) pixels
0xFF0C, 0xFEEC, 0xFEEB, 0xFEEA, 0xFEC9, 0xFEC9, 0xFE67, 0xFE67, 0xFEA7, 0xFE87, 0xFE46, 0xF5E4, 0xED84, 0xED43, 0xE503, 0xED63, // 0x0500 (1280) pixels
0xF5E3, 0xFE23, 0xFE44, 0xFE44, 0xFE44, 0xFE44, 0xFE24, 0xFE03, 0xF5A2, 0xED62, 0xF562, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0510 (1296) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE24, 0xFE44, 0xFE45, 0xFE66, 0xFEA6, 0xFEA7, 0xFEC8, 0xFEC8, 0xFEC9, 0xFEEA, 0xFEEB, // 0x0520 (1312) pixels
0xFEEB, 0xFEEA, 0xFEEA, 0xFEC9, 0xFEC9, 0xFE87, 0xFE46, 0xFEA7, 0xFEA7, 0xFE66, 0xFE25, 0xF5C4, 0xED63, 0xED23, 0xED62, 0xF5E3, // 0x0530 (1328) pixels
0xFE23, 0xFE44, 0xFE44, 0xFE44, 0xFE44, 0xFE24, 0xFE03, 0xF5C3, 0xF582, 0xF562, 0xED62, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0540 (1344) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE24, 0xFE44, 0xFE44, 0xFE65, 0xFE86, 0xFEA7, 0xFEA7, 0xFEA7, 0xFEC8, 0xFEC9, 0xFEC9, // 0x0550 (1360) pixels
0xFEC9, 0xFEC9, 0xFEC8, 0xFEA8, 0xFE66, 0xFE66, 0xFEA7, 0xFEA7, 0xFE86, 0xFE45, 0xF5E4, 0xED84, 0xED43, 0xED83, 0xFE44, 0xFE64, // 0x0560 (1376) pixels
0xFE84, 0xFEA6, 0xFEA7, 0xFEA7, 0xFEA7, 0xFEA5, 0xFE84, 0xFE64, 0xFE23, 0xF5C3, 0xED62, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0570 (1392) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF624, 0xFE24, 0xFE44, 0xFE65, 0xFE86, 0xFEA6, 0xFEA7, 0xFEA7, 0xFEA7, 0xFEA7, 0xFEA8, // 0x0580 (1408) pixels
0xFEC8, 0xFEA8, 0xFE87, 0xFE46, 0xFE66, 0xFEA7, 0xFEA7, 0xFEA6, 0xFE86, 0xFE45, 0xF5C4, 0xED63, 0xED23, 0xFE24, 0xFE84, 0xFEA6, // 0x0590 (1424) pixels
0xFEC8, 0xFECA, 0xFEEB, 0xFEEB, 0xFEEB, 0xFEEA, 0xFEC8, 0xFEA6, 0xFE64, 0xFE23, 0xF5C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x05A0 (1440) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF604, 0xFE24, 0xFE44, 0xFE64, 0xFE85, 0xFEA6, 0xFEA6, 0xFEA6, 0xFEA6, 0xFE86, 0xFE66, // 0x05B0 (1456) pixels
0xFE66, 0xFE45, 0xFE45, 0xFE86, 0xFEA7, 0xFEA6, 0xFEA6, 0xFE86, 0xFE85, 0xFE25, 0xF5C4, 0xED63, 0xED23, 0xFE24, 0xFE85, 0xFEC8, // 0x05C0 (1472) pixels
0xFECA, 0xFEEB, 0xFEEC, 0xFF0C, 0xFEEC, 0xFEEB, 0xFECA, 0xFEA7, 0xFE85, 0xFE64, 0xF5E3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x05D0 (1488) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF603, 0xFE24, 0xFE24, 0xFE44, 0xFE84, 0xFE85, 0xFEA5, 0xFEA6, 0xFEA6, 0xFE65, 0xFE66, // 0x05E0 (1504) pixels
0xFE66, 0xFEA7, 0xFEA7, 0xFEA7, 0xFEA6, 0xFEA6, 0xFEA5, 0xFE85, 0xFE85, 0xFE44, 0xF5E4, 0xED84, 0xED23, 0xF5A3, 0xFE85, 0xFEA7, // 0x05F0 (1520) pixels
0xFEC9, 0xFEEB, 0xFEEC, 0xFEEC, 0xFEEB, 0xFECA, 0xFEC8, 0xFEA6, 0xFE84, 0xFE64, 0xFFE0, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0600 (1536) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF603, 0xF624, 0xFE24, 0xFE44, 0xFE64, 0xFE84, 0xFE85, 0xFE85, 0xFEA6, 0xFEA7, 0xFEC8, // 0x0610 (1552) pixels
0xFEC8, 0xFEC8, 0xFEC8, 0xFEC8, 0xFEA7, 0xFEA6, 0xFEA5, 0xFE85, 0xFE85, 0xFE44, 0xF5E4, 0xED83, 0xED43, 0xE4E3, 0xF5A3, 0xFE45, // 0x0620 (1568) pixels
0xFE66, 0xFE87, 0xFE87, 0xFE88, 0xFE87, 0xFE66, 0xFE65, 0xFE44, 0xF5C3, 0xF582, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0630 (1584) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF5E3, 0xF603, 0xF624, 0xFE24, 0xFE44, 0xFE64, 0xFE84, 0xFE85, 0xFEA6, 0xFEA7, 0xFEC9, // 0x0640 (1600) pixels
0xFEC9, 0xFECA, 0xFECA, 0xFEC9, 0xFEC8, 0xFEA7, 0xFE86, 0xFE85, 0xFE65, 0xFE25, 0xF5C4, 0xED63, 0xE523, 0xF582, 0xF5E3, 0xFE23, // 0x0650 (1616) pixels
0xFE44, 0xFE64, 0xFE64, 0xFE64, 0xFE44, 0xFE23, 0xF5E3, 0xF582, 0xF562, 0xED62, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0660 (1632) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF5C3, 0xF5E3, 0xF603, 0xFE24, 0xFE44, 0xFE44, 0xFE44, 0xFE65, 0xFE86, 0xFEA8, 0xFEC9, // 0x0670 (1648) pixels
0xFECA, 0xFECA, 0xFECA, 0xFECA, 0xFECA, 0xFEC9, 0xFEA7, 0xFE66, 0xFE44, 0xF5E4, 0xED84, 0xED23, 0xF5A3, 0xFE44, 0xFE64, 0xFEA5, // 0x0680 (1664) pixels
0xFEA7, 0xFEC8, 0xFEC8, 0xFEA8, 0xFEA7, 0xFE85, 0xFE64, 0xFE23, 0xF5C3, 0xF562, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0690 (1680) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF5A3, 0xF5C3, 0xF5E3, 0xF603, 0xFE03, 0xFE23, 0xFE24, 0xFE44, 0xFE66, 0xFE87, 0xFEA9, // 0x06A0 (1696) pixels
0xFEC9, 0xFECA, 0xFECA, 0xFECA, 0xFECA, 0xFEC9, 0xFEA7, 0xFE86, 0xFE25, 0xF5C4, 0xED64, 0xE523, 0xFE23, 0xFE84, 0xFEA7, 0xFEC9, // 0x06B0 (1712) pixels
0xFEEB, 0xFEEB, 0xFEEC, 0xFEEB, 0xFEEB, 0xFEC9, 0xFEA6, 0xFE84, 0xFE23, 0xF582, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x06C0 (1728) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF5A2, 0xF5A3, 0xF5C3, 0xF5C3, 0xF5E3, 0xF5E3, 0xF5E3, 0xFE03, 0xFE25, 0xFE66, 0xFE88, // 0x06D0 (1744) pixels
0xFEA9, 0xFEC9, 0xFEC9, 0xFEC9, 0xFEC9, 0xFEA8, 0xFE87, 0xFE66, 0xF625, 0xF5C4, 0xED63, 0xE503, 0xFE04, 0xFE84, 0xFEA7, 0xFECA, // 0x06E0 (1760) pixels
0xFEEB, 0xFF0C, 0xFF0D, 0xFEEC, 0xFEEB, 0xFEC9, 0xFEA7, 0xFE84, 0xFE23, 0xF5A3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x06F0 (1776) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF5A1, 0xF582, 0xF5A3, 0xF5A3, 0xF5A3, 0xF5C3, 0xF5C3, 0xF5E3, 0xF5E3, 0xF605, 0xFE46, // 0x0700 (1792) pixels
0xFE67, 0xFE88, 0xFEA8, 0xFEA8, 0xFE88, 0xFE67, 0xFE66, 0xFE45, 0xF604, 0xF5E4, 0xED84, 0xED23, 0xED63, 0xFE84, 0xFE85, 0xFEA7, // 0x0710 (1808) pixels
0xFEC9, 0xFECA, 0xFEEA, 0xFECA, 0xFEC9, 0xFEA7, 0xFE85, 0xFE64, 0xF603, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0720 (1824) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFBE0, 0xF5C3, 0xF5A3, 0xF5C3, 0xF5C3, 0xF5C3, 0xF5E4, // 0x0730 (1840) pixels
0xF605, 0xFE25, 0xFE46, 0xFE46, 0xFE45, 0xFE25, 0xFE04, 0xF604, 0xF5E4, 0xF5E4, 0xF5A4, 0xED63, 0xE523, 0xED63, 0xF603, 0xFE44, // 0x0740 (1856) pixels
0xFE65, 0xFE65, 0xFE65, 0xFE45, 0xFE44, 0xFE44, 0xFE03, 0xFE23, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0750 (1872) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF5A2, 0xF5A3, 0xF5A3, 0xF5A3, // 0x0760 (1888) pixels
0xF5C3, 0xF5C3, 0xF5E3, 0xF5E3, 0xF5C3, 0xF5C3, 0xF5C3, 0xF5E3, 0xF5E4, 0xF5C4, 0xED84, 0xED23, 0xED83, 0xFE64, 0xFE84, 0xFE85, // 0x0770 (1904) pixels
0xFE85, 0xFE85, 0xFE84, 0xFE64, 0xFE24, 0xF5C3, 0xF562, 0xEDA2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0780 (1920) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF562, 0xED82, 0xF582, // 0x0790 (1936) pixels
0xF582, 0xF582, 0xF583, 0xF583, 0xF582, 0xF5A2, 0xF583, 0xF5A3, 0xF5C4, 0xED84, 0xED63, 0xED23, 0xFE44, 0xFEA5, 0xFEC8, 0xFEEB, // 0x07A0 (1952) pixels
0xFEEB, 0xFEEB, 0xFEEB, 0xFEC8, 0xFE85, 0xFE44, 0xF5C3, 0xFD40, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x07B0 (1968) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xED42, 0xED42, // 0x07C0 (1984) pixels
0xED42, 0xED62, 0xED62, 0xED62, 0xED62, 0xED62, 0xED62, 0xF583, 0xF5A3, 0xED84, 0xED43, 0xE503, 0xFE24, 0xFEA6, 0xFEC9, 0xFEEB, // 0x07D0 (2000) pixels
0xFF0D, 0xFEEC, 0xFEEB, 0xFEC9, 0xFEA5, 0xFE64, 0xF603, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x07E0 (2016) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x07F0 (2032) pixels
0xED42, 0xED42, 0xED42, 0xED42, 0xED42, 0xED42, 0xED42, 0xED62, 0xED83, 0xED83, 0xED83, 0xED43, 0xED83, 0xFE85, 0xFEA7, 0xFEC8, // 0x0800 (2048) pixels
0xFEC9, 0xFEC8, 0xFEA7, 0xFEA6, 0xFE84, 0xFE44, 0xFDA4, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0810 (2064) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0820 (2080) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE43, 0xFE84, 0xFE84, // 0x0830 (2096) pixels
0xFE84, 0xFE84, 0xFE64, 0xFE64, 0xF5E3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0840 (2112) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0850 (2128) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0860 (2144) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0870 (2160) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0880 (2176) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0890 (2192) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x08A0 (2208) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x08B0 (2224) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x08C0 (2240) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x08D0 (2256) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x08E0 (2272) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x08F0 (2288) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, // 0x0900 (2304) pixels
