Micro USB Controller X/Y Axis Rotation Windows Calibration
Hi everyone!
I am working on a custom game controller with an Arduino micro. I have gotten everything to work using the Joystick library. But, my problem is that when I open the game controller from my devices menu (in Windows 10) to calibrate the controller, its inputs are only X Axis Rotation and Y Axis rotation. As I move the potentiometers on the controller, the X and Y Axis Rotation Values change but the plus sign used in the calibration never moves. So, the computer is reading the inputs but isn't translating that to moving the plus sign around on the calibration.
Does anyone have any suggestions?
If I need to clarify something that I can do that too. Thank you in advance!
Do you have a working game controller, so that you can find out how the program reacts?
I've deleted your other cross-post .
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
