Wasn't sure which category to post this in, so please let me know if I need to do this elsewhere.
Genuine Arduino Micro through Amazon. Has letters "51-20" on the board.
Chip works fine whin I load Blink. If I upload the sketch attached here, the USB port disconnects. Problem persists until I reload the bootloader via upload blink/pressing reset. Chip works fine once bootloader is back, but will start dropping the port once I upload this sketch.
I have tried this with 3 different arduino Micros on two different windows PC's. Plugged into a breadboard with some jumpers and hardware attached, and all by itself with only the USB cable attached. Two different USB cables.
At this point, I can only assume that the Sketch is wack-a-do.
Please don't make fun of my code, I'm still debugging and testing!
Thanks for your help.
Steve
These displays use I2C to communicate, 2 pins are required to
interface. There are multiple selectable I2C addresses. For backpacks
with 2 Address Select pins: 0x70, 0x71, 0x72 or 0x73. For backpacks
with 3 Address Select pins: 0x70 thru 0x77
/* writeDigitRaw(location,bitmask) SAR
matrix.writeDigitRaw(0,B00111000); //L
matrix.writeDigitRaw(1,B01110111); //A
matrix.writeDigitRaw(3,B01110011); //P
matrix.writeDigitRaw(4,B01101101); //S`
#include <Wire.h> // Enable this line if using Arduino Uno, Mega, etc.
#include <Adafruit_GFX.h>
#include "Adafruit_LEDBackpack.h"
Adafruit_AlphaNum4 alpha4 = Adafruit_AlphaNum4();
int relayPin = 4;
int buttonPin = 7;
int voltPin = A4;
char curSts = 'X';
char displayStat;
volatile bool buttPress = false;
bool relayOn = false;
char relaySB;
bool AWait4V = true;
bool tooHigh = false;
float minVolts = 3.7;
float maxVolts = 15.0;
bool waitt = false;
bool showTimer = false;
bool drawDots = false;
float input_voltage;
unsigned long timerCur;
unsigned long timerEnds;
unsigned long time2Charge = 120000L; //= 2 * 1000 * 60; // in millis ( min)
unsigned long time2Wait = 60000L; //1 * 1000 * 60; // in millis ( min)
unsigned long tLeft;
//#ifndef __AVR_ATtiny85__
Serial.println("7 Segment Backpack Test");
//#endif
int bright = 2;
alpha4.begin(0x70); // pass in the address
alpha4.setBrightness(bright);
pinMode(buttonPin, INPUT_PULLUP);
pinMode(voltPin , INPUT);
pinMode(relayPin , OUTPUT);
attachInterrupt(digitalPinToInterrupt(buttonPin), ButtInterrupt, RISING);
curSts = 'X';
pinMode(LED_BUILTIN, OUTPUT);
Serial.print("exit Setup");
} //end setup
//buttinterrupt IS FIRED OFF BY INTERRUPT FROM PIN falling FROM HIGH TO LOW. (BUTTON HAS BEEN PRESSED THEN RELEASED)
void ButtInterrupt()
{ buttPress = true; //values are backwards
Serial.print("Butt activated");
void DisplayStatX()
{ if (waitt) {
displayStat = 'W';
else if (tooHigh) {
displayStat = 'H';
else if (curSts == 'A') {
displayStat = 'A';
else if (curSts == 'O') {
displayStat = 'O';
else if (curSts == 'X') {
displayStat = 'X';
}//end DisplayStatX
void DisplayVolts()
{ bool btrue = true;
alpha4.clear();
int d1 = floor(input_voltage / 10);
int d2 = floor(input_voltage) - (d1 * 10);
int d3 = 10 * (input_voltage - (d1 * 10) - d2); //
char dd;
char ee;
d1 = 6;
dd = sprintf(dd, "%i1", d1);
if (d1 == 0){dd = '0';}
if (d1 == 1){dd = '1';}
if (d1 == 2){dd = '2';}
if (d1 == 3){dd = '3';}
if (d1 == 4){dd = '4';}
if (d1 == 5){dd = '5';}
if (d1 == 6){dd = '6';}
if (d1 == 7){dd = '7';}
if (d1 == 8){dd = '8';}
if (d1 == 9){dd = '9';}
--dd = (char)d2;*/
alpha4.writeDigitAscii(0, 'W');//dd);
alpha4.writeDigitAscii(1, dd, btrue);
alpha4.writeDigitAscii(2, char(d3));
alpha4.writeDigitAscii(3, displayStat);
Serial.print(input_voltage);
Serial.print(" d1: ");
Serial.print(d1);
Serial.print(" d2: ");
Serial.print(d2);
Serial.print(" d3: ");
Serial.print(d3);
// matrix.print(input_voltage);
alpha4.writeDisplay();
} //end DisplayVolts
void DisplayTimer()
{ alpha4.clear();
DisplayStatX();
if (curSts != '9')
{ tLeft = timerEnds - timerCur;
//int hr = tLeft / 3600; /////////// Watch it here if timer is set > 1 hour!
unsigned long mins = tLeft / 60000L;
unsigned long sec = tLeft / 1000L;
unsigned long min1 = mins / 10L;
unsigned long min2 = mins - (min1 * 10L);
int mini = round(sec / 60);
Serial.print("Left : ");
Serial.print(tLeft);
Serial.print(" minutes: ");
Serial.print(mins);
Serial.print(" mini: ");
Serial.print(mini);
Serial.print(" sec: ");
Serial.print(sec);
Serial.print(" min1: ");
Serial.print(min1);
Serial.print(" min2: ");
Serial.print(min2);
Serial.print(" timerEnds: ");
Serial.print(timerEnds);
Serial.print(" timerCur: ");
Serial.print(timerCur);
alpha4.writeDigitAscii(0, min1);
alpha4.writeDigitAscii(1, min2);
alpha4.writeDigitAscii(2, ' ');
} // End DisplayTimer
Serial.println(); Serial.println(); Serial.print("Start Loop");
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on -- proof of life..
delay(500); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off
input_voltage = analogRead(voltPin);
input_voltage = 4.8 * ((input_voltage * 5.0) / 1024.0);
//input_voltage = roundf(input_voltage * 10);
//input_voltage = round(input_voltage / 10);
input_voltage = round(10 * input_voltage) / 10;
timerCur = millis(); //millis since sketch started
//Check Button
//ButtPress is set in ButtInterrupt
// Sts goes X => A => O with button presses
if (buttPress == true)
{ buttPress = false; //reset
waitt = false; // button pressed / turn off wait
curSts = 'O';
timerEnds = timerCur + time2Charge;
curSts = 'A';
AWait4V = true;
curSts = 'X';
} //Butt Pressed
if (curSts == 'A' && !waitt && timerEnds < timerCur /*&& !AWait4V*/) // Start Wait
{ waitt = true;
timerEnds = timerCur + time2Wait;
else if (curSts == 'A' && waitt && timerEnds < timerCur) // EndWait
{ waitt = false;
AWait4V = true;
if (curSts == 'O' && timerEnds < timerCur) //Stop Override after timer ends
{ waitt = false;
curSts = 'X';
if (AWait4V && curSts == 'A' && input_voltage > minVolts)
{ AWait4V = false;
waitt = false;
if (input_voltage > maxVolts) {
tooHigh = true;
else {
tooHigh = false;
if (curSts == 'O' && !tooHigh)
relaySB = true;
else if (curSts == 'A' && !AWait4V && !waitt && !tooHigh)
relaySB = true;
else {
relaySB = false;
if (relaySB && !relayOn)
digitalWrite(relayPin, HIGH);
relayOn = true;
if (!relaySB && relayOn)
digitalWrite(relayPin, LOW);
relayOn = false;
Serial.print ("CurSts :");
Serial.print (curSts);
Serial.print (" Waitt: ");
Serial.print (waitt);
Serial.print (" Wait4V: ");
Serial.print (AWait4V);
Serial.print(" Time2Charge: ");
Serial.print(time2Charge);
Serial.print(" Time2Wait: ");
Serial.print(time2Wait);
DisplayStatX();
DisplayVolts();
if (curSts != 'X')
delay (1000);
DisplayTimer();
delay(3000);
} //End Loop
