Microcontroller Without reference
Hello,
I have bought an ESC, and I can't program so I would like Flash but no ref on microcontroller like you can see on this picture.
Could you help me to find the reference ?
Thank you
If you cannot program and you dont know what microcontroller it is, what do you intend to do even if the microcontroller could be identifed ?
You might want to ask in the RCGROUPS forum, someone there may have attempted to program that particular speed controller.
Hello,
I can't program with RC Transmitter. I would like flash with my arduino
It could be any number of things, but the STM8F003F3 or STM8S103F3 is available and common in that sort of SO20 package. It is widely used in low cost applications, and it has a pin out consistent with your markings as far as they go.
The typical test points for in-circuit programming an STM8 are on your board, namely, reset on pin 4, Vss (GND) on pin 7, Vdd (+5V) on pin 9, and SWIM on pin 18. The test point on pin 8 is unusual as that pin (Vcap) is not involved in programming; it's an internally regulated 1.8V used for the core processor and would be connected to a ~1 uF capacitor.
There's a lot of good information with regard to hacking STM8-based boards, if that's what it is, at this site: Breakout Boards · TG9541/stm8ef Wiki · GitHub
Presuming the device is programmable, what is it you want to do with it?
it's an ESC for RC airplane, some options are not available by default.
I would like enable this with BLHeli software
az1234:
Then presumably the 'BLHeli software' gives an indication of the microcontrollers it supports ?
Yes but I haven't the reference of microcontroller.
The ref is erased on the microcontroller
The BLHeli github repository has PDF documents with photos of the supported boards under the "Atmel" and "SiLabs" folders. In a quick look I don't see anything like your photo nor any board with an SO20 package for the microcontroller. GitHub - bitdump/BLHeli: BLHeli for brushless ESC firmware
What components are on the other side of the ESC board?
Basically.
We don't know. It will be up to you to figure it out. When you do know get back to us and let us know.
Of course, you can have your thread moved to gigs and collaborations where someone can do research for you, for a fee.
The obvious place to research this would have been RCGROUPS forum of course, which I presume @az1234 has already tried.
If they could not identify the particular brand\model of speed controller, then I dont see how it would help knowing which microcontroller has been used.
It does not appear to be an Arduino .........................
I suspect it is a Nuvoton N76E003AT20
4 programmer connectors and one on the other side on the 8th pin. You would have to take a better picture to trace the programmer pads to the MCU pins. For the N76E003AT20 that should be pins:
4 = RST
7 = GND
8 = DAT
9 = VDD
18 = CLK
that would connect to a Nulink programmer
more info
https://www.rcgroups.com/forums/showpost.php?p=45013041&postcount=6647
Merci à tous pour votre aide.
@hmeijdam, yes it can be that.
But I don't known if I can flash it with BLheli or Simon K with an arduino
