Microcontroller
Hey guy, my project is to use uC32 as a base for CAN-Bus Shield. So does anyone know if the Digilent Chipkit is compatible with the Arduino software?
Error Code.txt (6.21 KB)
WARNING: library SparkFun_CAN-Bus_Arduino_Library-master claims to run on [avr] architecture(s) and may be incompatible with your current board which runs on [pic32] architecture(s).
That library is not compatible with non-AVR boards (all the errors happen when it tries to directly interact with registers that only exist on AVR boards). You need to get a library that supports the architecture you're using.
