Micrometer reader usb
Hello
I have a problem about read micrometer value , Now right i can read one micrometer value
connect to Arduino nana from this link http://www.instructables.com/id/Interfacing-a-Digital-Micrometer-to-a-Microcontrol/step3/Reading-the-Mitutoyo-output/ but i need to one more connecting ( 2 micrometer). I’m trying to write code for support my condition
but it’s not working.
Can you help me about code.
//*** Setup micrometer 1 *************
int req = 5; //mic11 REQ line goes to pin 5
int dat = 2; //mic11 Data line goes to pin 2
int clk = 3; //mic11 Clock line goes to pin 3
int i = 0;
int j = 0;
int k = 0;
float Value;
byte mydata[14];
long num;
//*** Setup micrometer 2 *************
int req2 = 9; //mic2 REQ line goes to pin 9
int dat2 = 6; //mic2 Data line goes to pin 6
int clk2 = 7; //mic2 Clock line goes to pin 7
int i2 = 0;
int j2 = 0;
int k2 = 0;
float Value2;
byte mydata2[14];
long num2;
  pinMode(req, OUTPUT);
  pinMode(clk, INPUT);
  pinMode(dat, INPUT);
  digitalWrite(clk, HIGH); // enable internal pull ups
  digitalWrite(dat, HIGH); // enable internal pull ups
  digitalWrite(req,LOW); // set request at LOW
  pinMode(req2, OUTPUT);
  pinMode(clk2, INPUT);
  pinMode(dat2, INPUT);
  digitalWrite(clk2, HIGH); // enable internal pull ups
  digitalWrite(dat2, HIGH); // enable internal pull ups
  digitalWrite(req2,LOW); // set request at LOW
  //***  Micrometer 1*********
  digitalWrite(req2, LOW);
  digitalWrite(req, HIGH); // generate set request
  for( i = 0; i < 13; i++ ) {
    k = 0;
    for (j = 0; j < 4; j++) {
         while( digitalRead(clk) == LOW) {
      } // hold until clock is high
      while( digitalRead(clk) == HIGH) {
      } // hold until clock is low
        bitWrite(k, j, (digitalRead(dat) & 0x1)); // read data bits, and reverse order )
    mydata[i] = k;
  char buf[7];
  for(int lp=0;lp<6;lp++){
    buf[lp]=mydata[lp+5]+'0';
  buf[6]=0;
  num=atol(buf); //assembled measurement, no decimal place added
  Value=num*0.001;
 Serial.println(Value);
  digitalWrite(req, LOW);
  digitalWrite(req2, HIGH); // generate set request
  for( i2 = 0; i2 < 13; i2++ ) {
    k2 = 0;
    for (j2 = 0; j2 < 4; j2++) {
       while( digitalRead(clk2) == LOW) {
      while( digitalRead(clk2) == HIGH) {
      bitWrite(k2, j2, (digitalRead(dat2) & 0x1)); // read data bits, and reverse order )
    mydata2[i2] = k2;
  char buf2[7];
  for(int lp2=0;lp2<6;lp2++)
  buf2[lp2]=mydata2[lp2+5]+'0';
  buf2[6]=0;
  num2=atol(buf2); //assembled measurement, no decimal place added
  Value2=num2*0.001;
  Serial.println(Value2);
I would suggest the code section that reads and decodes the Micrometer values is written as a function where you pass the pin numbers for req/dat/clk and it returns a float value representing the micrometer reading.
Something like below (Untested)
byte req = 5; //mic11 REQ line goes to pin 5
byte dat = 2; //mic11 Data line goes to pin 2
byte clk = 3; //mic11 Clock line goes to pin 3
byte req2 = 9; //mic2 REQ line goes to pin 9
byte dat2 = 6; //mic2 Data line goes to pin 6
byte clk2 = 7; //mic2 Clock line goes to pin 7
  pinMode(clk, INPUT_PULLUP);
  pinMode(dat, INPUT_PULLUP);
void loop(){
  float Value = readMicrometer(req,clk,dat);
  Value = readMicrometer(req2,clk2,dat2);
float readMicrometer(byte reqPin, byte clkPin, byte datPin){
  byte mydata[14];
  digitalWrite(reqPin, HIGH); // generate set request
  for( byte i = 0; i < 13; i++ ) {
    byte k = 0;
    for (byte j = 0; j < 4; j++) {
      while( digitalRead(clkPin) == LOW) {}; // hold until clock is high
      while( digitalRead(clkPin) == HIGH) {}; // hold until clock is low
      bitWrite(k, j, (digitalRead(datPin) & 0x1)); // read data bits, and reverse order )
    mydata[i] = k;
  char buf[7];
  for(byte lp=0;lp<6;lp++){
  buf[6]=0;
  long num=atol(buf); //assembled measurement, no decimal place added
  return num*0.001;
Thank you so much Riva for your help, but it still not work it just read micrometer 1 and one time as picture below.
matsuo:
It was not meant as a complete example but a pointer to how to do it. Below is code with (hopefully) all the extra bits needed.
  pinMode(clk2, INPUT_PULLUP);
  pinMode(dat2, INPUT_PULLUP);
void loop(){
  byte mydata[14];
    byte k = 0;
    mydata[i] = k;
  digitalWrite(reqPin, LOW); // clear set request
  char buf[7];
  buf[6]=0;
  return num*0.001;
Thanks you again Riva , I have a one more question , Can you help me?
Now it’s work for connect 2 micrometer but when i just connect one micrometer it will not work!!
How to auto detect for solve this a problem ?
matsuo:
Talk about moving goalposts ;D
The below compiles okay but I’m at work so cannot test it. If there is no micrometer attached it will hopefully abort trying to read it after a second or two and return -1.0 as the measured length.
#define timout 1000UL         // Timout (1 second) if no micrometer detected.
void loop(){
  byte mydata[14];
    byte k = 0;
      unsigned long time = millis();
        if ((millis() - time) > timout) return -1.0;
    mydata[i] = k;
  char buf[7];
  buf[6]=0;
  return num*0.001;
Thanks Riva . It's work :wink:
matsuo:
Glad it works okay and nice that you took the time to tell me.
