Hi there,
So, I have currently an project for which I will use an arduino consisting of:
- Eletromyography sensor (acquisition frequency = 100Hz);
- Piezoeletric sensor as a respiratory belt (acquisition frequency = 100Hz);
- Microphone (acquisition frequency = 42kHz)
All of which for 24h monitoring and syncronized in time!
For microphone implementation I've read this article: APC’s April 2023 issue is on sale now! | TechRadar
My problems:
- Is it possible to integrate all of those 3 sensors and having a perfect audio quality (that is, with audio of a normal pc recording?
- What is the best option to save all that data (sd card?), having in consideration that all of the 3 syncronized parameters would have to be digitally processed in matlab or whatever?
Thanks in advance!
What sort of Arduino?
The zero or due is the only one that stands a chance, but better would be a Teensy 3.6.
You get Audio but not perfect quality with the internal A/D, you would need an external A/D.
I think an SD card is your only hope of storing Audio, however for storing other data at the same time is tricky.
Grumpy_Mike:
I have an arduino UNO and an arduino MEGA. On the tutorial they use a MEGA!
Grumpy_Mike:
I would'nt need the audio by itself (like an .wav) but rather the values - I'm intending to use machine learning!
Couldn't I use like a 24h hour sound recorder (something external) and connect it to arduino, or something like that?
fat16lib helped with code to sample at CD quality level, 16-bit@44100 KHz, and store to SD card. I was using a '1284P, but I think he had it working on just a '328P. External ADC needed for the fast conversion time, 10-bit @ 10KHz wasn't good enough for me.
http://forum.arduino.cc/index.php?topic=180769.0
CrossRoads:
Can you please link me to your final code please (if the code in the link u sent was improved)? Would be a HUGE help!
CrossRoads:
What external ADC did you used?
Thanks for your reply
Read the thread, everything we did is there, software and hardware description. I only breadboarded the hardware, never built it up into something I could deploy. Not yet, anyway.
