Having a bit of an issue. I have a NodeMCU driving three NPN mosfets to an RGB LED strip. Powering the LED strip is 12 volts currently, powering the NodeMCU is the Vout from a step down converter of sorts from the 12 volt supply and this is going into the NodeMCU's 3.3v pin. Finally, powering my microphone is a different 3.3v pin. All grounds are connected on the breadboard except I have the microphone grounded to the NodeMCU GND pin.
I am doing beat detection and increasing the brightness of the LED strip when a certain voltage threshold is met.
All of this works well if I power the NodeMCU from my computer's USB port (aka not applying 3.3volts from the step down converter). I get a "silent" reading near zero, and it records sound spikes well when powering via USB.
The issue occurs when I do power it from the step down converter, although I don't think the converter is the issue. I get very erratic voltage readings ranging anywhere from near zero to 3.1 volts even when it is "silent" in the room.
I am guessing there is some sort of "electrical noise" or something due to all of the components together? That would be my first guess. Should I ground the microphone to somewhere other than the NodeMCU? (although I tried this and that alone did not fix the issue)
Any advice on how to get more consistent readings would be greatly appreciated!
No experience with this NodeMCU, but had a look at the onboard supply diagram here.
Seems logical (to me) to adjust the buck converter to 5volt, and connect to the V-in pin.
The onboard regulator will drop it to 3.3volt, and remove some of the hash in the process.
Keep the mic connected to 3.3volt.
Leo..
Leo..
Thanks for the reply! I should have been more specific, my converter is this one which does not have a 5v option. I do however have a 7805 voltage regulator I will try out in the morning though. Is "hash" the term for whatever it is (electrical charge/noise?) that could be causing erratic measurements?
Asking the right question is 80% of the answer and I do not know all the proper terminology.
MarkT:
Yes, a microphone amplifier is almost never going to work well from a switch-mode supply, use a linear
regulator.
Thank you for the advice, the "silent" readings are hovering around 0 again.
Could you possibly explain why the switching supply doesn't work?
I'm back to a previous issue using a 7805, because although I'm currently using 12 volts the end goal is to make it work with a 24 volt supply and I don't know if the 7805 can handle that heat dissipation
It can work if it's well-designed and well-filtered. Microphone preamps have gain somewhere in the ballpark of 100-1000 (depending on the gain/volume control) and if noise gets into the circuit it's going to get amplified. Power supply switching noise is "nasty" because it's (relatively) high-power high-frequency pulses with lots of harmonics and it can get "transmitted" all over the place. But, most of the noise is supersonic and that's a good thing for an audio amplifier. 50/60Hz power line hum can also be an issue with linear power supplies in audio equipment.
If the 7805 is just powering the microphone-board, I'd guess you'll be OK.
DVDdoug:
Thank you for your explanation that is quite helpful. The microphone board is not the only thing being powered, the NodeMCU is also powered by the regulator. From what I have seen the max draw to the board is about 350 mA on startup but goes down significantly during normal operation.
I noticed the 7805 got pretty warm/hot very quickly. That was the purpose of the switching regulator, 91% efficiency and stayed cool. Is the linear my best bet and if so should I just heat sink it?
Have you placed bypass capacitors around the LM7805?
Check the data sheet for the LM7805.
You need at least a 0.1uF and 10uF caps on the input and output of the regulator.
TomGeorge:
Tom....
Thanks for pointing that out. Are the capacitors in regard to electrical noise or the heat issue? (or both)
