Microphone readings
Im using a microphone sensor and want the readings to range from 0 - 1023
But it only goes up to 672
What can i change in the code to get 1023?
const int sampleWindow = 50; // Sample window width in mS (50 mS = 20Hz)
unsigned int sample;
   unsigned long startMillis= millis();  // Start of sample window
   unsigned int peakToPeak = 0;   // peak-to-peak level
   unsigned int signalMax = 0;
   unsigned int signalMin = 1024;
   // collect data for 50 mS
   while (millis() - startMillis < sampleWindow)
      sample = analogRead(0);
      if (sample < 1024)  // toss out spurious readings
         if (sample > signalMax)
            signalMax = sample;  // save just the max levels
         else if (sample < signalMin)
            signalMin = sample;  // save just the min levels
   peakToPeak = signalMax - signalMin;  // max - min = peak-peak amplitude
   double volts = (peakToPeak * 3.3) / 1024;  // convert to volts
   Serial.println(peakToPeak);
Reference page to the rescue:
https://www.arduino.cc/en/Reference/Map
--Michael
mrears92:
What is special about 1024? Once you have your readings, the scale is unimportant. But to answer your question, you can simply scale it with a different constant:
double sig = (peakToPeak * 3.3) / 672;  // convert to calibrated level
mrears92:
The question is, why? Do you mean that is the maximum level, which the mike module hits long before the maximum volume has been reached? If that is the case, converting to 1023 or whatever won't improve things. There should be some kind of intelligent scaling and saturation detection happening after you convert to volts. Otherwise you are just engaging in a pretense of accuracy that you don't really have. You should also be thinking ahead to a calibration method, because there isn't any predictable gain in any part of your audio, electronic or software path.
I don’t think that a 10-bit ADC is likely to need this either:-
