Microphone sensitivity on Nano 33 BLE Sense
Hello and good morning,
I am using Nano 33 BLE Sense for audio recognition project which the project are done in the closed area with the presence of echo in the room. I need to know whether the IC can capture my voice when i am standing as far as 5m from the IC.
I collect the audio samples for Training and Testing stage which shows good percentage result for both stages. But when the code generated and i upload the code into the processor of the Nano 33 BLE Sense and do the offline audio recognition testing, the accuracy results are bad.
I had try to change the PDM.setGain value from 127 to 255 in the code, but it doesnt work.
I am new in using the Arduino IC and also writing code. I need your advice regarding on the sensitivity of the mic on this IC.
  1. Does this IC suitable for capturing audio from long distant source, for example 5m?
  2. How can i increase the sensitivity of the mic?
  3. Which part of the code that i need to do modification in order to increase the sensitivity of the mic on the IC?
  4. Does the IC have noise and echo cancellation?
Your advice and opinion are highly appreciated. Thank you.
