MicroPython on the GIGA R1 Document
The titled topic content contains incorrect use for installing MicroPython on the GIGA R1.
On my raspberry pi 400:
The line: dfu-util -w -a 0 -d 2341:0366 -D GIGAR1_MP_FW.dfu
fails - the option -w is invalid.
Apparently, removing this offending option allows upload of the Micropython environment - or does it? In Thonny I can't execute anything in the shell.
Also Thonny does not show a GIGA Micropython, simply a generic. Could we please have better documentation??
What version of dfu-util do you have on your system? (Try dfu-util -v)
On 0.11, which is the latest one installable via HomeBrew, the -w option is supported and documented in the man page:
       -w, --wait
              Wait until matching device appears on the USB bus.
So it's strange that you don't have it. Maybe your system has an older version of dfu-util?
Also, we recommend using Arduino Lab for MicroPython which has some usability improvements and should provide better feedback on what's going on.
Let us know :slight_smile:
Hi alranel,
thanks for your timely reply. The utility was loaded using apt from the latest raspbian archive ande and says it is:
dfu-util -V
dfu-util 0.9
So that's the answer. Raspberry pi (ARM) versions are usually a little behind.
As for 'Arduino Lab for Micropython' - I can't find an ARM version - again, not a surprise. I'm currently installing OpenMV IDE. I'll update later with any progress. Thanks again.
Here's my predicament:
$ /usr/bin/dfu-util --verbose -w -a 0 -d 2341:0366 -D GIGAR1_MP_FW.dfu
dfu-util 0.11
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
libusb version 1.0.26 (11724)
DFU suffix version 11a
Waiting for device, exit with ctrl-C
^C
While Tormod's has been invaluable and patient with my previous inquiries, I feel obliged to run this past the Arduino GIGA team before approaching him since this issue is not being caused by dfu-util directly.
Pardon my ignorance but I have the following serial ports for communication to varied genuine Arduino and some other vendor (e.g. Sony Spresence, Himax, etc.) boards:
ttyACM0 thru ttyACM5
ttyUSB0 thru ttyUSB3
The GIGA is connected through ttyACM4 and works for exercises with Arduino IDE 2.4.
There is a port setting for the dfu-util program. Do I have to use it to designate the GIGA? Is there an example illustrating its use?
I would prefer not to disconnect all the other boards just to flash the firmware since it is not the best practice in my environment. What should I do to flash the firmware successfully?
Please help! Thanks.
Regards.
P.S.
Also, it would be useful to have some documentation on the purpose of -a parameter for dfu-util if it is a requirement for the GIGA.
