I worked pretty hard to make a simple sketch proving how slow the micros() method is on the Nano 33 BLE Sense:
#include "mbed.h"
#include "nrf_delay.h"
#include "nrf_gpio.h"
#define OUTPUT_PIN NRF_GPIO_PIN_MAP(1,11)
unsigned long startClock;
unsigned long stopClock;
unsigned long arithmeticMinuend = 4294967295;
unsigned long arithmeticSubtrahend = 2147483648;
unsigned long arithmeticDifference = 0;
unsigned long timeDifference1 = 0;
unsigned long timeDifference2 = 0;
//Assume 1 to 4 clock cycles (15.625 to 62.5 ns) is required for every...
//* call of micros();
//* subtraction of two unsigned longs.
//Therefore we should not be able to measure the time to execute either task by using the micros() - startClock technique, as...
//* micros() - startClock = 0 in either case.
while (!Serial);
nrf_gpio_cfg_output(OUTPUT_PIN);
startClock = micros();
stopClock = micros();
timeDifference1 = microsecondsToSubtract2LongsOnce();
timeDifference2 = microsecondsToSubtract2LongsTwice();
Serial.print("timeDifference1 = ");
Serial.print(timeDifference1);
Serial.print(" us.\ntimeDifference2 = ");
Serial.print(timeDifference2);
Serial.println(" us.");
microsecondsToSubtract2LongsOnceMeasuredWithScope();
delay(100);
microsecondsToSubtract2LongsTwiceMeasuredWithScope();
delay(100);
microsecondsToToggleOutputPinMeasuredWithScope();
while(1) {
//Prints 8 us:
unsigned long microsecondsToSubtract2LongsOnce() {
return stopClock - startClock;
//Prints 9 us:
unsigned long microsecondsToSubtract2LongsTwice() {
arithmeticDifference = arithmeticMinuend - arithmeticSubtrahend;
//Measured 18 us on scope:
void microsecondsToSubtract2LongsOnceMeasuredWithScope() {
nrf_gpio_pin_toggle(OUTPUT_PIN);
void microsecondsToSubtract2LongsTwiceMeasuredWithScope() {
//Measured 500 ns on scope:
void microsecondsToToggleOutputPinMeasuredWithScope() {
I compare time measurements I made with oscilloscope to the ones I made using micros(). Doing the math we get that the # of clock cycles required for one micros() call = (0.5*(18000 - 500) ns)/15.625 ns = 560 clock cycles!!!
Can someone give an example for measuring time on this board which doesn't require more than 10 clock cycles???
Please take a look at this same discussion on SO; I have discovered a strategy which is an order of magnitude faster than this, using mBed's us_ticker_read method. Please let me know if you know of a faster solution which will beat my 42 clock cycles. I would love to hear about it!
For short intervals, you should be able to read cycle counts from either the ARM Core SysTick Timer, or the ARM DWT Cycle Counter (you'd probably have to enable the DWT first.)
startTime = SysTick->VAL; // 24bit counter, probably resets at ~1ms. Counts Down!
// or
start = DWT->CYCCNT; //CYCCNT wraps at 32bits; never resets, counts up.
// With:
// Somewhere in system init
CoreDebug->DEMCR |= CoreDebug_DEMCR_TRCENA_Msk;
DWT->CTRL |= DWT_CTRL_CYCCNTENA_Msk;
I don't know how those will be affected by (or affect) low power modes and such.
