Micros() show the same two consecutive
Here is my code. I want to ask why I use Arduino Due to record the time and analog value, it will print two same time point value. Kindly to check in the figure, this is what I get from this code.
Why does it show the same value?
float z[2900][3];
int s;
int p;
int inPin = 5;
 pinMode(9,OUTPUT);
 digitalWrite(9,HIGH);
 pinMode(10,OUTPUT);
 digitalWrite(10,HIGH);
 analogReadResolution(12);
 pinMode(inPin,INPUT);
if (Serial.available() > 0) {
   int inByte1 = Serial.read();
   switch (inByte1) {
   case '2':
   digitalWrite(9,LOW);
   delay(1500);
   delay(300);
   digitalWrite(10,LOW);
   delay(300);
   //delay(76000); //等待extraction step
   p=0;
       while(p < 1){
       if(digitalRead(inPin) == 1){
        //delayMicroseconds(7420);
       for (int s=0;s<2620;s++){
        z[s][0] = micros();
        z[s][1] = analogRead(A1);
        p = p+1;
       /*while (p < 75){
       //x[p][3] = millis();
        z[s][0] = micros();
        z[s][2] = analogRead(A2);
        p = p+1;
       z[s][1] = z[s][2] + z[s][1];
       z[s][1] = z[s][1]/p;
        for(int s=0;s<2620;s++){
          Serial.print(z[s][0]);
          Serial.print(",");
          Serial.print(z[s][0]-z[0][0]);
          Serial.print(",");
          Serial.print(z[s][1]);
          Serial.print("\n");
          delay(3);
micros returns unsigned long, not float
So you mean that I need to convert unsigned long to float?
No, I mean you need to record (store) the value returned by micros() in an unsigned long (uint32_t) variable.
long
You mean like this? store the value in unsigned long.
No, not really.
Either use an array of struct (timestamp (uint32_t) and sample (uint16_t)), or two arrays one of uint32_t for the timestamps, and one of uint_16_t for the samples.
Edit: I've installed a decent calculator app on this phone now. The timestamp you highlighted requires just over 26 bits to accurately represent, but the float data type has only a 23 bit mantissa.
Now I try and it seems work. Thank you very much because I try to solve this problem for more than one day and did not find this problem on the forum. Thank you!
