Hey all,
I'm trying to store arrays to a 2GB SD card which I can then access later. I am using the EtherTen 328P board which contains a microSD socket.
I am able to read/write files to the card in small testing sketches, however I have come across an issue in my main program.
My program seems to reset and start over at times when I am running my program, which I can see using the Serial Monitor. The serial port also sometimes shows garbage and random characters while running the program. Usually the program will restart midway through a Serial.Print() statement.
I am using the standard SD commands (#include <SD.h>). The arrays I am writing can be 400 bytes max.
My question is, might the SD commands be taking up too much SRAM, if I only have 2KB of it? I also read/write from the Serial often in my program, could this contribute to the issue?
My code is long and confusing, so I wont make you read through it, I'm just curious if this is a known issue.
Cheers,
Joshua
