Hi.
I am using the information from
https://github.com/Azure/azure-iot-sdks/blob/master/doc/setup_iothub.md
in order to test the integration between Arduino UNO and Azure IoT.
I don't have any issues setting up the Azure components but when I try to use the Azure IoT libraries I can not compile because the library triggers an error saying that ir "claims to run on [samd] architecture(s) and may be incompatible with your current board which runs on [avr] architecture(s)".The libraries that I am using are:
As I mentioned above I am using Arduino UNO for testing purposes but reading the configurations tested by Microsoft they include Arduino Zero and Arduino MKR1000, they fit the samd arquitecture requirement.
So I have two questions:
- Is there some alternative to achieve the IoT integration using Arduino UNO?
- Would it be possible to get some library compatible with Arduino UNO?
Regards,
Carlos.
