Microstrain Inertia Link setup with Duemilanove
hey guys i could really use your help for a senior project. i got it to move servos but my problem is that i have Microstrain Inertia Link but cannot get it to talk to the duemilanove which our team just bought. i tried the serial.read and other codes i found online and i cannot get anything from it. From an individual online, i found the following to start the proper format to which i could add too but i still get nothing. from the source code available from Microstrain, a coding involving 0xC2 for acceleration and angular rates will be necessary but i want to know first how to get anything from it. ANY HELP WOULD BE GREATLY APPRECIATED. Thanks
#include <NewSoftSerial.h>
NewSoftSerial imu(7, 5);
imu.begin(9600);
if (imu.available())
Serial.print("IMU: ");
Serial.print(imu.read(), BYTE);
So how are you connecting this to the Arduino?
It has an RS232 output so you can't just connect it up to the Arduino lines, you need a level converter like the MAX232 chip.
Your code shows you are not sending it anything, do you expect it just to send serial data without giving it a nudge?
well i was hoping to initiate the communication to see if something happens. is this a chip necessary? so there is no way around this? we are trying to build a rocket and all programming is essentially complete but the communication with the Inertia Link is holding me up.
Thank you
I asked :-
You did not answer so it is a bit difficult to answer the following questions. Assuming that you are using the RS232 output of this device.
Yes or some other way of converting +12 to -12V signals into 0 to 5V signals and inverting them so that -12 gives +5V and +12V gives 0V. It can be done without this chip but you still need a fist full of transistors and diodes to do it.
No.
Also if you have connected an RS232 signal directly into your Arduino you might have blown up an input pin.
