I hooked up my LCD yesterday, it works really well, and have no complaints. It is hooked up to the 10k pot it came with. It also came with a diode. Is it supposed to be hooked up to a diode? This LCD came without instructions. I was reading amazon comments and one guy hooked up the diode and killed his UNO. I do not want to hook up the diode, but fear I may be doing more damage. Any body know about it? The LCD is microtivity blue background white letters, 16x2. Thanks.
Right, that diode was put in the circuit by someone who has absolutely no concept of electronic engineering. Doing wire it up like they have.
If you want to use the backlight, start with a 100 ohm resistor from pin 15 to +5v. If it doesn't light up, it means that it is one of the backlights which uses large currents (there are some which can use up to 0.5A which will trip the fuse on the Arduino!!). You can limit the current these draw by going for around a 10R resistor. The backlight will be dim, but it should still light up.
To repeat, the diode is a stupid thing of them to have suggested.
Edit:
According to the comments on the amazon page, this isn't one of the high current backlights, and they have successfully used a 560 ohm resistor.
Could you give the rest of us a clue about the circuit and the diode that you are discussing?
Don
pins 15 and 16 are the Anode and Cathode of the backlight LED which is a blue LED with a forward voltage of 4.2V
It seems that the perpetrator of that diagram really doesn't understand the meaning of the 'forward voltage' parameter. Has anyone taken them up on the request printed under the diagram?
Don
Edit: "Has anyone taken them up on the request printed under the diagram?" No answer so far, so I did it.
Fortunately, that is a self-healing polyfuse, but may I gather take some hours to reset. It should not be permanently "killed".
If you unplug the board completely from the USB port and any other power supply, the fuse usually recovers after around 5 minutes.
Im guessin they are hoping on the diodes 0.7v voltage drop to bring the 5v down to the 4.2v backlight voltage, it wont however limit the current if anything goes wrong
Hi all!
This is microtivity, the seller of the LCD module.
On the modules a 100 ohm SMD resistor is soldered to the pin 15.
When you apply 5V to the backlight, the current is limited to 16 mA.
If you choose to add the diode provided, the current will be reduced to 10mA (voltage = 4.3V).
Hope this explanation clears your concerns.
microtivity
Im guessin they are hoping on the diodes 0.7v voltage drop to bring the 5v down to the 4.2v backlight voltage, it wont however limit the current if anything goes wrong.
The diode alone is never the correct solution because the '4.2v backlight voltage' is not a rating for the device, it is a characteristic of a properly operating device.
In other words, if you have somehow limited the backlight current to the correct value then the resulting forward voltage of a typical LED will be approximately 4.2 volts.
On the other hand you cannot somehow limit the applied voltage to 4.2 volts and expect the resulting LED current to be correct, it just doesn't work that way (as it would for a linear device such as a resistor).
Don
It looks good to me now that I can see the circuit board.
Don
