Microwave Anti-Beep Mod
My Magic Chef microwave oven produces five loud annoying beeps at the end of each countdown, and won't stop even after I've opened the door. So I designed a mod that uses a Pro Mini to monitor the display and press the Stop button when the countdown reaches one second. The "early" termination prevents the five beeps. All the details are in a Github repo:
https://github.com/gbhug5a/Microwave_Anti-Beep_Mod
This only works for my model HNN1110W purchased in 2020, but something similar might work for other microwaves with the same feature. Remember that microwave ovens are mains-connected devices with high-voltage capacitors, and can be dangerous to open up and work on.
Why not simply remove the beeper?
Because the beep is useful. The keypad is just membrane, and it's hard to tell if you've pressed a key. The beep on keypress tells you that without having to look at the display. Also, I still want something to happen when the countdown finishes. Now I get two fast beeps instead of the 5-second barage.
where would be the fun of it :slight_smile:
Yeah. I mean it's supposed to be a hobby, right? Actually, it's kinda neat that it works. I wasn't sure I would be able to figure out how the oven drives the display. It turned out to be a really oddball algorithm that I've never seen before. Anyway, it was fun working on it for a couple days.
I kind-of miss the mechanical "ding" of my dial-microwave.
My first microwave, 1980, about $600.
Tom.. :smiley: :+1: :coffee: :australia:
Good on you for using Arduino to make a practical impact in your daily.
