MICS-6814
Dear all,
I try to interface a MICS 6814 based board like this one 13, without I2C support, with an arduino compatible board. I looked for a library supporting it, but I couldn’t find anything except code for the I2C interfaced sensor.
Did anybody used that sensor before and know how I may use it?
Thanks for your help.
You forgot to provide links to the used hardware. The datasheet I found doesn't mention an I2C version of that chip with any word. Given you also meant that chip, there is no library support necessary as the input will simply use some analog input pins.
