Hello, I am trying to control MIDI thru via AJAX. Unfortunately, I found that both:
MIDI_CREATE_INSTANCE(HardwareSerial, Serial, MIDI);
MIDI_CREATE_INSTANCE(SoftwareSerial, SoftSerial, MIDI);
causes an issue with the html code (listed below). When MIDI_CREATE_INSTANCE is included, the html repeats itself in the
section. I had thought that switching to SoftwareSerial would resolve this but sadly that is not the case. I am using a Arduino Uno and have a Arduino Mega on the way thinking having 2 hardware serial ports may help.
Any help would be greatly appreciated!
Arduino Html Code: (basically from Arduino AJAX Web Server for Reading a Switch Automatically.)
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 65);
IPAddress myDns(192, 168, 1, 1);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
EthernetServer server(80);
String midiThruString;
String HTTP_req;
extern bool midiThru;
void htmlServer() {
// listen for incoming clients
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
HTTP_req += c; // save the HTTP request 1 char at a time
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: keep-alive");
client.println();
// AJAX request for switch state
if (HTTP_req.indexOf("ajax_switch") > -1) {
// read switch state and send appropriate paragraph text
GetSwitchState(client);
} else { // HTTP request for web page
// send web page - contains JavaScript with AJAX calls
client.println("<!DOCTYPE html>");
client.println("<html>");
client.println("<head>");
client.println("<title>Arduino Web Page</title>");
client.println("<script>");
client.println("function GetSwitchState() {");
client.println("nocache = \"&nocache=\"\+ Math.random() * 1000000;");
client.println("var request = new XMLHttpRequest();");
client.println("request.onreadystatechange = function() {");
client.println("if (this.readyState == 4) {");
client.println("if (this.status == 200) {");
client.println("if (this.responseText != null) {");
client.println("document.getElementById(\"switch_txt\")\.innerHTML = this.responseText;");
client.println("}}}}");
client.println("request.open(\"GET\", \"ajax_switch\" + nocache, true);");
client.println("request.send(null);");
client.println("setTimeout('GetSwitchState()', 1000);");
client.println("}");
client.println("</script>");
client.println("</head>");
client.println("<body onload=\"GetSwitchState()\">");
client.println("<h1>Arduino AJAX Switch Status</h1>");
client.println("<p id=\"switch_txt\">Switch state: Not requested...</p>");
client.println("</body>");
// client.println("</html>");
// display received HTTP request on serial port
Serial.print(HTTP_req);
HTTP_req = ""; // finished with request, empty string
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
// send the state of the switch to the web browser
void GetSwitchState(EthernetClient cl)
if (midiThru) {
cl.println("MIDI IS ON");
else if (!midiThru) {
cl.println("MIDI IS OFF");
