Midi Beater code
Hello, I was wondering if anyone could help me figure out why I can’t get the servos to operate at the same time in polyphony as it were. LEDs are synced with their respective servos without problem and they fire one after the other with my step sequencer but it’s as if each of the representative midi notes can only be played one after the other and not all together at once if needed. This is Mike Cook’s code and I’m not sure if his intention was polyphony or that I’ve made an error somewhere
// MIDI Beater by Mike Cook Feb 2014
#include <Servo.h>
Servo beatServo[8];  // create servo object to control a servo
byte midiActivity = 7; // activity LED
byte servoPin[] = {2, 3, 4, 8, 9, 10, 14, 15};  // define what pins the servo is on
byte ledPins[] = {5, 6, 18, 17, 11, 12, 13, 16};  // defines the pins the LEDs are on
byte servoPos[] = {0, 0, 0, 0, 0, 0, 0, 0}; // to determine  if LED should be on or off
byte servoOffPos[] = {15, 15, 15, 15, 15, 15, 15, 15}; // position the note off should go to
byte lowestServo = 73;// MIDI note for lowest servo
byte lowestServoOff = 28; // MIDI note for lowest servo off
int channel = 0;
  for(int i =0; i<8; i++){
  beatServo[i].attach(servoPin[i]);
  pinMode(ledPins[i], OUTPUT);
  digitalWrite(ledPins[i], HIGH);   // turn off LED
     beatServo[i].write(servoOffPos[i]);  // positions the servos to the off point
   pinMode(midiActivity, OUTPUT);
   digitalWrite(midiActivity, HIGH); // turn off MIDI for us light
   Serial.begin(31250);  // for MIDI
  checkMIDI();
void checkMIDI() {
   static int state=0;
   static boolean noteDown = LOW;
   static byte note;
   byte incomingByte;
  if (Serial.available() > 0) {
    // read the incoming byte:
    incomingByte = Serial.read();
   switch (state){
      case 0:
    // look for as status-byte, our channel, note on
    if (incomingByte == (144 | channel)){
         noteDown = HIGH;
         state=1;
    // look for a status-byte, our channel, note off
    if (incomingByte == (128 | channel)){
         noteDown = LOW;
         state=1;
      if( ((incomingByte & 0xf) == channel) && (state == 1)) // light up command for us
        digitalWrite(midiActivity, LOW); // turn on MIDI for us light
       case 1:
       // get the note to play or stop
       if(incomingByte < 128) {
          note=incomingByte;
          state=2;
       else{
       state = 0;  // reset state machine as this should be a note number
       case 2:
       // get the velocity
         playNote(note, incomingByte, noteDown); // turn the servo
         state = 0;  // reset state machine to start
void playNote(byte note, byte velocity, int down){
    byte index = note - lowestServo;
    // if velocity = 0 on a 'Note ON' command, treat it as a note off
    if ((down == HIGH) && (velocity == 0)){
      down = LOW;
   if(note>= lowestServo && note < lowestServo + 8){ // is it in the range of our servos
   if(down == LOW) velocity = servoOffPos[index];   // make it the off position
    beatServo[index].write(velocity); // make servo move to angle given by velocity
    if(velocity > servoPos[index]) digitalWrite(ledPins[index], LOW); else digitalWrite(ledPins[index], HIGH);
    servoPos[index] = velocity;
     else { // set off position
     if( (note>= lowestServoOff) && (note < (lowestServoOff + 8)) ){ // is it in the range of our off position control
     if(down == HIGH)servoOffPos[note - lowestServoOff] = velocity;  // set the note off position
Have you a wiring diagram of you project ?
Your code is incredibly hard to read. The convention is ONE STATEMENT PER LINE. For damned good reasons.
You are not being charged per line of code, so use lots more lines.
Put EVERY { on a line BY ITSELF. Put EVERY } on a line BY ITSELF.
Use Tools + Auto Format. Often.
@PaulS, don't bother, the original post is well over a year old :)
PieterP:
@PaulS, don’t bother, the original post is well over a year old :slight_smile:
Thanks. I missed the necropsy in the thread.
