Midi Button Matrix is putting out wrong Notes
Hi!
I have a problem and i hope i get help here :slight_smile:
I want to use an old toy guitar as midicontroller.
It has 12 button switches on the neck and it uses a button matrix
with 3 columns and 4 rows.
I am using an Arduino Micro and want to be able to play 12 notes via
MidiUsb. (hooked up to the computer)
Now i wanted to use the “Ex.11 Button Matrix” code from the
Midi Controller Library, as it seems perfect for my needs:
a 4 x 3 matrix which puts out 12 chromatic tones.
So far so good, BUT no matter what i do, the arduino puts out
the same note as last note of a row AND as first note of the next row.
Like this:
C, C#, D, D#
D#, E, F, F#
F#, G, G#, A
instead of doing a chromatic scale.
this is the code used, taken from the Midi Controller Library
(https://github.com/tttapa/MIDI_controller/releases/tag/3.1.0)
This is an example of the "ButtonMatrix" class of the MIDI_controller library.
Connect a 4 Ă— 3 matrix of buttons with the rows to pins 2, 3, 4 and 5,
and the columns to pins 6, 7 and 8.
Pull-up resistors are not necessary, because the internal ones will be used.
If you want to be able to press multiple buttons at once, add a diode
in series with each button, as shown in the schematic on the Wiki:
https://github.com/tttapa/MIDI_controller/wiki/Hardware
The note numbers are specified in the 'addresses' array.
Map accordingly in your DAW or DJ software.
Written by tttapa, 24/09/2017
#include "MIDI_Controller.h" // Include the library
const uint8_t velocity = 0b1111111; // Maximum velocity (0b1111111 = 0x7F = 127)
const uint8_t addresses[4][3] = {   // the note numbers corresponding to the buttons in the matrix
  {  1,  2,  3 },
  {  4,  5,  6 },
  {  7,  8,  9 },
  { 10, 11, 12 }
// Create a new instance of the class 'ButtonMatrix', called 'buttonmatrix', with dimensions 4 rows and 3 columns, with the rows connected to pins 2, 3, 4 and 5
// and the columns connected to pins 6, 7 and 8, that sends MIDI messages with the notes specified in 'addresses' on MIDI channel 1, with velocity 127
ButtonMatrix<4, 3> buttonmatrix({2, 3, 4, 5}, {6, 7, 8}, addresses, 1, velocity);
void setup() {}
  // Refresh the buttons (check whether the states have changed since last time, if so, send it over MIDI)
  MIDI_Controller.refresh();
Thanks in advance!!! Any help highly appreciated
That's a bug indeed.
I fixed it in f4c4c2a.
Pieter
Thank you!!!!! :slight_smile:
PieterP:
Pieter
Ok, i now changed the .cpp file
compiled the code and now i got a diminished scale like:
C, D#, G, C
C#, E, G#, C#
D, F, A, D
please help,sadly i am still a total noob with this :confused:
If a libraries been fixed, reinstall the whole library, not just one file.
Ok! I will do that!
Ok, i deleted the old Midi Controller Library, installed the new, but the problem is the same..
it puts out a diminished scale...
Ok, i figured it out myself!!
In case anybody has the same problem...
you have to change this:
{ 1, 2, 3 },
{ 4, 5, 6 },
{ 7, 8, 9 },
{ 10, 11, 12 }
into this
{ 1, 5, 9 },
{ 2, 6, 10 },
{ 3, 7, 11 },
{ 4, 8, 12 }
Great to hear!
