MIDI code problem with writing
Hello Im making a MIDI project and I found this MIDIUSB - Arduino Reference
library that will make my arduino mega 2560 USB to send midi data my question is when I type the code
MidiUSB.sendMIDI(midiEventPacket_t event);
MidiUSB.flush()
It says an error message that MIDI USB isnt declared how should I declare it ? Im new to programing so any help would be useful :slight_smile:
error Message :
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\Adun\AppData\Local\Temp\arduino_modified_sketch_716049\sketch_feb22a.ino: In function 'void setup()':
sketch_feb22a:2: error: 'MidiUSB' was not declared in this scope
sketch_feb22a:2: error: 'midiEventPacket_t' was not declared in this scope
exit status 1
option enabled in File -> Preferences.
You probably didn't include the library:
#include "MIDIUSB.h"
as shown in the example here but there's no way to know for sure because you didn't post all your code.
If you do post your code, post it in code tags.
Pete
el_supremo:
Pete
Im making a MIDI controller the controller cant make sound on its own only through a computer ...
so what kind of code should I write ? I wrote this
#include "MIDIUSB.h";
 MidiUSB.flush();
and this is the error
C:\Users\Adun\AppData\Local\Temp\arduino_modified_sketch_556792\sketch_feb22a.ino:2:22: fatal error: MIDIUSB.h: No such file or directory
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
Use the arduino library manager to install the midiusb library.
And the include of MIDIUSB.h should be at the beginning of the sketch, not in the setup() function.
Pete
el_supremo:
Pete
This is my code and I got another error T_T
/Code
MidiUSB.flush()
/Code
ERROR :
In file included from C:\Users\Adun\AppData\Local\Temp\arduino_modified_sketch_450401\sketch_feb26a.ino:1:0:
C:\Users\Adun\Documents\Arduino\libraries\MIDIUSB\src/MIDIUSB.h:18:2: error: #error MIDIUSB can only be used with an USB MCU.
exit status 1
what is a USB MCU ? Does mega 2560 not have it ? Or do I need to activate it ? thanks for the help :slight_smile:
The Arduino Mega doesn't support MIDI USB natively.
MIDI Controller library
Pieter
PieterP:
Pieter
hello thanks for the link I but I have a question about PJRC Encoder library do I need to install it when I dont use jogwheels ? I use only rotary potentiometers and linear pots.
Yes, unless you uncomment RotaryEncoder.h from the MIDI_Controller.h file and delete RotaryEncoder.cpp and RotaryEncoder.h.
