MIDI control and power issue related question
Hi there,
I am having what I think may be a power issue. I am using 4x arduino type microcontrollers (2x Pro Micros and 2x Adafruit bluefruit feather LE's) on a single USB hub with a mac pro late 2013.
Each of these has 2x sensors (HC-SR04 pings sensor and RC522 RFID reader). Each circuit sends midi simultaneously. However, I find that one or two circuits continually become inactive and I need to replug the usb cable to bring them back to life. I'm guessing this is a power issue as the hub is unpowered?
Also, these circuits are spitting out loads of midi at a very high rate all the time, MIDI which is snet without a delay, though I'm not sure if this should be an issue, perhaps that could be the other cause.
Basically, I want advice on the correct type of hub to get to power this setup so I know that at least I can rule out a power related issue? I'd appreciate any tips! Many thanks :slight_smile:
Monoth:
Why are they sending out MIDI all of the time? MIDI Controllers should only send updates when you turn a knob or push a button, not all the time.
My cheap USB hubs sometimes stop working when a lot of devices are plugged in for a long time, especially when using an Arduino that I update a lot to (maybe because they switch USB types from CDC for upload to MIDI when running?). Just unplugging them usually solves the problem.
Pieter
