Hey all,
Im having some issues with my MIDI Controller code. My goal for is to have 6 pots that send CC, the CC values should be able to be changed with the press of one of two buttons. The buttons should change the CC of the pots by accessing a multi dimensional array consisting of CC values which should change the CC that all 6 pots are controlling essentially changing the page of CC values. This will be indicated by an OLED screen. The issues im having are that my pots seemingly aren't being read, or sending CC. And my buttons aren't adding or removing one from my counter, instead random values are churning out. I would really appreciate some advice on how to fix these issues and possibly get some guidance on getting this project in working order.
Here is the code
#include <MIDIUSB.h>
#include <MIDI.h>
#include "U8glib.h"
U8GLIB_SH1106_128X64 u8g(13, 11, 10, 9);
void printArray ( const int [][ 6 ] ); // prototype
const int rows = 4;
const int columns = 6;
int buttonleft = 0;
int buttonright = 1;
int buttonPushCounter = 0;
boolean buttonState = LOW; // current state of the button
boolean lastButtonState = LOW; // previous state of the button
const int NPots = 6;
int screenpos = 0;
const int potPin[NPots] = {A9, A8, A7, A6, A5, A4};
int potVal[NPots];
int potCState[NPots] = {0}; // Current state of the pot;
int potPState[NPots] = {0}; // Previous state of the pot;
int PTime[NPots] = {0};
int timer[NPots] = {0};
int TIMEOUT = 20 ;
int potVar = 0;
int varThreshold = 1;
int pot1cc = 0 ;
int pot2cc = 1 ;
int pot3cc = 2 ;
int pot4cc = 3 ;
int pot5cc = 4 ;
int pot6cc = 5 ;
int midiCState[NPots] = {0}; // Current state of the midi value; delete 0 if 0 pots
int midiPState[NPots] = {0}; // Previous state of the midi value; delete 0 if 0 pots// microKorg CC's 27= LFO1 freq, 76= LFO2 freq, 12= MOD fx LFOspeed 93= MOD fx depth, 13= Delay time, 94= Delay depth
int ccpos [11][6] = { { 1, 2, 3, 4, 5, 6 }, { 7, 8, 9, 10, 11, 12 }, { 13, 14, 15, 16, 17, 18 }, { 19, 20, 21, 22, 23, 24}, {25, 26, 27, 28, 29, 30}, {31, 32, 33, 34, 35, 36}, {37, 38, 39, 40, 41, 42}, {43, 44, 45, 46, 47, 48}, {49, 50, 51, 52, 53, 54}, {55, 56, 57, 58, 59, 60}, {27, 76, 12, 93, 13, 94} };
char *menu[] = {"pg 01", "pg 02", "pg 03", "pg 04", "pg 05", "pg 06", "pg 07", "pg 08", "pg 09", "pg 10", "pg 11",};
byte midiCh = 1; //* MIDI channel to be used
byte note = 12; //* Lowest note to be used; 36 = C2; 60 = Middle C
byte cc = 1; //* Lowest MIDI CC to be used
void draw(void) {
// graphic commands to redraw the complete screen should be placed here
u8g.setFont(u8g_font_courB24);
//u8g.setFont(u8g_font_osb21);
u8g.drawStr( 15, 40, menu[screenpos]);
//set up pots
for(int i = 0; i < NPots; i++)
pinMode(potPin[i], INPUT);
pinMode(buttonleft, INPUT_PULLUP); //sets up buttons
pinMode(buttonright, INPUT_PULLUP);
//read the pots and check if theyre different form last time
//if its different send out MIDI
for (int i = 0; i < NPots; i++)
potVal[i] = analogRead(potPin[i]);
if(potVal[i] != potPState[i])
midiCState[i] = map(potCState[i], 0, 1023, 0, 127); // Maps the reading of the potCState to a value usable in midi
potVar = abs(potCState[i] - potPState[i]); // Calculates the absolute value between the difference between the current and previous state of the pot
if (potVar > varThreshold) { // Opens the gate if the potentiometer variation is greater than the threshold
PTime[i] = millis(); // Stores the previous time
timer[i] = millis() - PTime[i]; // Resets the timer 11000 - 11000 = 0ms
boolean potMoving;
if (timer[i] < TIMEOUT) { // If the timer is less than the maximum allowed time it means that the potentiometer is still moving
potMoving = true;
else {
potMoving = false;
if (potMoving == true) { // If the potentiometer is still moving, send the change control
if (midiPState[i] != midiCState[i]) {
controlChange(1, ccpos [screenpos][i], potVal[i]);
MidiUSB.flush();
// read the state of the pushbutton value:
buttonState = digitalRead(buttonright);
// compare the buttonState to its previous state
if (buttonState != lastButtonState)
if (buttonState == HIGH)
// if the current state is HIGH then the button
// went from off to on:
screenpos++; // add one to counter
if (screenpos > 11)
screenpos = 0;
Serial.println(screenpos);
buttonState = digitalRead(buttonleft);
screenpos--; // remove one from counter
if (screenpos < 1)
screenpos = 11;
// Arduino MIDI functions MIDIUSB Library
void noteOn(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
void controlChange(byte channel, byte control, byte value) {
midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
MidiUSB.sendMIDI(event);
