MIDI Controller using two XBee
Hello Guys,
Thanks from now!
What I need is to encode the signal that arrives at recetptor Xbee in MIDI control by Arduino.
  • The XBee can send signal alone without Arduino, which is able to control LEDs, relays, etc. Motor ...
But I would take what activates an LED signal and convert MIDI control.
Link Ex: xBee to xBee (S1) Direct Wireless Communication and Switching (Part 1.1) - YouTube
I'm starting with arduino now, I know nothing about programming, I would like to help me with the programming part, to interpret the sign of the XBee Midi control.
All downloaded programs and pro Xbee and Arduino MIDI library, but I can not use.
Thanks for helping me.
Tosos downloaded programs and pro Xbee and Arduino MIDI library, but I can not use.
I have no idea what this means, or why you can't use existing libraries. It sounds like a homework assignment in a programming class, where you are supposed to do more than demonstrate that you can use a library. In which case, YOU are the one that is supposed to be doing the programming.
What I need is to encode the signal that arrives at recetptor XBee, Arduino, and by converting MIDI Control.
  • The XBee can send signal alone without Arduino is able to control LEDs, relays, motor etc ...
    I made the experience here with LEDs, but I would like to:
Take what activates an LED sign, and convert MIDI (CC80) control.
I need 4 buttons for specific controls, in case (CC), so I can remotely control a pedal (turn on and off effects).
I know it's possible, but do not know where to start ...
I would like to help me with programming !!
help
