I want to make an instrument that plays MIDI files from an SD card. I am using an Arduino Mega 2560. The output will be digital i/o signals sent to digital pins for each "note" ( ex: a different led for each midi note (one per pin)). Disregard velocity for now. I need the noteON and noteOFF bytes to turn on and off each digitalPin for each note, respectively, in time with the music. I am using the MD_MIDIFile library from marco_c. I am also running into the error message "Error compiling for board Arduino Mega or Mega 2560" which I am also unsure how to resolve.
How do I debug the MIDI data to read and then send an i/o output to a specific digitalPin for each note, instead of a direct MIDI send? (line 13 in the code below:).
// Test playing a succession of MIDI files from the SD card.
// Example program to demonstrate the use of the MIDFile library
// Just for fun light up a LED in time to the music.
// Hardware required:
// SD card interface - change SD_SELECT for SPI comms
// 3 LEDs (optional) - to display current status and beat.
// Change pin definitions for specific hardware setup - defined below.
#include <SdFat.h>
#include <MD_MIDIFile.h>
#define USE_MIDI 1 /// THIS IS LINE 13!!! set to 1 to enable MIDI output, otherwise debug output
#if USE_MIDI // set up for direct MIDI serial output
#define DEBUG(x)
#define DEBUGX(x)
#define DEBUGS(s)
#define SERIAL_RATE 31250
#else // don't use MIDI to allow printing debug statements
#define DEBUG(x) Serial.print(x)
#define DEBUGX(x) Serial.print(x, HEX)
#define DEBUGS(s) Serial.print(F(s))
#define SERIAL_RATE 57600
#endif // USE_MIDI
// SD chip select pin for SPI comms.
// Arduino Ethernet shield, pin 4.
// Default SD chip select is the SPI SS pin (10). (53 for mega)
// Other hardware will be different as documented for that hardware.
const uint8_t SD_SELECT = 53;
// LED definitions for status and user indicators
const uint8_t READY_LED = 7; // when finished
const uint8_t SMF_ERROR_LED = 6; // SMF error
const uint8_t SD_ERROR_LED = 5; // SD error
const uint8_t BEAT_LED = 4; // toggles to the 'beat'
const uint16_t WAIT_DELAY = 2000; // ms
#define ARRAY_SIZE(a) (sizeof(a)/sizeof(a[0]))
// The files in the tune list should be located on the SD card
// or an error will occur opening the file and the next in the
// list will be opened (skips errors).
const char *tuneList[] =
"1.MID", // simplest and shortest file
"2.MID",
// These don't play as they need more than 16 tracks but will run if MIDIFile.h is changed
//#define MIDI_FILE "SYMPH9.MID" // 29 tracks
//#define MIDI_FILE "CHATCHOO.MID" // 17 tracks
//#define MIDI_FILE "STRIPPER.MID" // 25 tracks
SdFat SD;
MD_MIDIFile SMF;
void midiCallback(midi_event *pev)
// Called by the MIDIFile library when a file event needs to be processed
// thru the midi communications interface.
// This callback is set up in the setup() function.
#if USE_MIDI
if ((pev->data[0] >= 0x80) && (pev->data[0] <= 0xe0))
Serial.write(pev->data[0] | pev->channel);
Serial.write(&pev->data[1], pev->size-1);
Serial.write(pev->data, pev->size);
#endif
DEBUG("\n");
DEBUG(millis());
DEBUG("\tM T");
DEBUG(pev->track);
DEBUG(": Ch ");
DEBUG(pev->channel+1);
DEBUG(" Data ");
for (uint8_t i=0; i<pev->size; i++)
DEBUGX(pev->data[i]);
DEBUG(' ');
void sysexCallback(sysex_event *pev)
// Called by the MIDIFile library when a system Exclusive (sysex) file event needs
// to be processed through the midi communications interface. Most sysex events cannot
// really be processed, so we just ignore it here.
DEBUG("\nS T");
DEBUG(pev->track);
DEBUG(": Data ");
DEBUG(' ');
void midiSilence(void)
// Turn everything off on every channel.
// Some midi files are badly behaved and leave notes hanging, so between songs turn
// off all the notes and sound
midi_event ev;
// All sound off
// When All Sound Off is received all oscillators will turn off, and their volume
// envelopes are set to zero as soon as possible.
ev.size = 0;
ev.data[ev.size++] = 0xb0;
ev.data[ev.size++] = 120;
ev.data[ev.size++] = 0;
for (ev.channel = 0; ev.channel < 16; ev.channel++)
midiCallback(&ev);
void setup(void)
// Set up LED pins
pinMode(READY_LED, OUTPUT);
pinMode(SD_ERROR_LED, OUTPUT);
pinMode(SMF_ERROR_LED, OUTPUT);
pinMode(BEAT_LED, OUTPUT);
// reset LEDs
digitalWrite(READY_LED, LOW);
digitalWrite(SD_ERROR_LED, LOW);
digitalWrite(SMF_ERROR_LED, LOW);
digitalWrite(BEAT_LED, LOW);
Serial.begin(SERIAL_RATE);
DEBUG("\n[MidiFile Play List]");
// Initialize SD
if (!SD.begin(SD_SELECT, SPI_FULL_SPEED))
DEBUG("\nSD init fail!");
digitalWrite(SD_ERROR_LED, HIGH);
while (true) ;
// Initialize MIDIFile
SMF.begin(&SD);
SMF.setMidiHandler(midiCallback);
SMF.setSysexHandler(sysexCallback);
digitalWrite(READY_LED, HIGH);
void tickMetronome(void)
// flash a LED to the beat
static uint32_t lastBeatTime = 0;
static boolean inBeat = false;
uint16_t beatTime;
beatTime = 60000/SMF.getTempo(); // msec/beat = ((60sec/min)*(1000 ms/sec))/(beats/min)
if (!inBeat)
if ((millis() - lastBeatTime) >= beatTime)
lastBeatTime = millis();
digitalWrite(BEAT_LED, HIGH);
inBeat = true;
if ((millis() - lastBeatTime) >= 100) // keep the flash on for 100ms only
inBeat = false;
void loop(void)
static enum { S_IDLE, S_PLAYING, S_END, S_WAIT_BETWEEN } state = S_IDLE;
static uint16_t currTune = ARRAY_SIZE(tuneList);
static uint32_t timeStart;
switch (state)
case S_IDLE: // now idle, set up the next tune
int err;
DEBUGS("\nS_IDLE");
currTune++;
if (currTune >= ARRAY_SIZE(tuneList))
currTune = 0;
// use the next file name and play it
DEBUG("\nFile: ");
DEBUG(tuneList[currTune]);
err = SMF.load(tuneList[currTune]);
if (err != MD_MIDIFile::E_OK)
DEBUG(" - SMF load Error ");
DEBUG(err);
digitalWrite(SMF_ERROR_LED, HIGH);
timeStart = millis();
state = S_WAIT_BETWEEN;
DEBUGS("\nWAIT_BETWEEN");
DEBUGS("\nS_PLAYING");
state = S_PLAYING;
case S_PLAYING: // play the file
if (!SMF.isEOF())
if (SMF.getNextEvent())
tickMetronome();
state = S_END;
case S_END: // done with this one
DEBUGS("\nS_END");
SMF.close();
midiSilence();
case S_WAIT_BETWEEN: // signal finished with a dignified pause
if (millis() - timeStart >= WAIT_DELAY)
state = S_IDLE;
default:
state = S_IDLE;
EDIT: First and foremost I need to resolve this compilation error first. Any help appreciated! Thanks
EDIT EDIT: Got the compilation error resolved, now how about the main problem?
