Midi filtertering of stop start messages
Ok I think I figured it out.
By changing "clk=0;" to clk=23; in both places!
It appears now to start bang on time.
I was just about to post
There is nothing fundamentally different between the first start and a stop/start
So now, your very first start will be 1 tick too soon. You could also change it to this
    if ((data == midi_clock) && (play_flag == 1)) {
      if (clk == 0) digitalWrite(tempoled, HIGH);
      if (clk == 7) digitalWrite(tempoled, LOW);  // this should light it up for 25% of the time
      clk = (clk+1) % 24;
      Serial.write(midi_clock); // send midi clock to out... Provides tempo!
which reduces the amount of times digitalWrite() is actually called and then leave all your clk=0 statements
You guys got it sussed. The increment comes to at the begining of the if statement, it probably should come at the end and then you can reset it to '0' It must have been a little early before as well
      if (clk / 6) digitalWrite(tempoled, LOW);  // this should light it up for 25% of the time
      else digitalWrite(tempoled, HIGH);
      clk++;
      clk = clk % 24;                                 // 24 clock messages per beat
and i actually think that it should be like this for continue, you don't reset the clock it is 'continue' after all
    if (data == midi_continue) { // if midi in continue
      Serial.write(midi_continue); // send midi out continue
      play_flag = 1;
      // clk=0; don't reset the clock for continue
I wasn't sure what that was supposed to do.. more of a pause/un-pause or more of a no-op.
It continues after 'stop' from the point where it stopped.
We should probably turn the led off when it receives a 'stop' as well.
A million thanks to you both for the generous help!
Yes, I realise I have been under the illusion the led was turning off with each stop. I will take a bash at that!
I wonder if I could ask you both once again for your help?
I want to send a midi note to a module to indicate audibly the tempo along with the LED. I have tried adding this but I'm afraid the coding won't compile correctly.
   else if ((data == midi_clock) && (play_flag == 1)) {
      if (clk / 2) digitalWrite(tempoled, LOW); //digitalWrite(tempoled, LOW);  // percentage of lit time
      MIDI.sendNoteOn(60, 127, 1);
      else digitalWrite(tempoled, HIGH); //digitalWrite(tempoled, HIGH);
      MIDI.sendNoteOn(60, 0, 1);
      clk++;
      clk = clk % 24;
What do I need to alter in the code please?
Your if/else statement does not contain { or } so only one statement is being executed with those which means your sendNoteOn() function is being called every time. You need to go back to when the led is only toggled at the correct time, not every time
      if (clk == 0) {
        // insert note here
      if (clk == 7) {
        // insert note here
      clk = (clk+1) % 24;
Totally ! Also send the noteOn when you turn the LED on and send noteOff when you turn the LED off. It's perfect just like that.
That's fantastic! That's much clearer to me now and easier to add any extras I may need down the line! I've added in some extra code as I wanted to use GM midi to access some percussion sounds from a synth chip to create a metronome triggered by the sequencer or master clock. Below is my updated code for anyone who may need it. Thanks immensely blh64 and Deva_Rishi for your time and help!
#define drumchan           9
// general midi drum notes
#define note_snaredrum    37 // rimshot!
// MIDI clock as per Little Scale
byte midi_start = 0xfa;
byte midi_stop = 0xfc;
byte midi_clock = 0xf8;
byte midi_continue = 0xfb;
static uint8_t clk = 0;
// Variables
int tempoled = 13;
int play_flag = 0;
byte data;
// Setup
  Serial.begin(31250);
  pinMode(tempoled, OUTPUT);
// Program
  if (Serial.available() > 0) {
    data = Serial.read();
    if (data == midi_start) { // if midi in start
      Serial.write(midi_start); // send midi out start
      play_flag = 1;
      clk = 0;
      play_flag = 1;
    if (data == midi_stop) { // if midi in stop
      Serial.write(midi_stop); // send midi out stop
      play_flag = 0;
      if (clk == 0) {
        noteOn(drumchan,  note_snaredrum, 100);
      if (clk == 7) {
        noteOff(drumchan,  note_snaredrum, 0);
      clk = (clk + 1) % 24;
// Send a MIDI note-on message.  Like pressing a piano key
// channel ranges from 0-15
void noteOn(byte channel, byte note, byte velocity) {
  midiMsg( (0x90 | channel), note, velocity);
// Send a MIDI note-off message.  Like releasing a piano key
void noteOff(byte channel, byte note, byte velocity) {
  midiMsg( (0x80 | channel), note, velocity);
// Send a general MIDI message
void midiMsg(byte cmd, byte data1, byte data2) {
  Serial.write(cmd);
  Serial.write(data1);
  Serial.write(data2);
:slightly_smiling_face:
