I'm new here and also a newbe with arduino stuff and programming.Until now, I found how to proceed with my project, and that is thanks to this forum. So I would like first to say thanks :)!
Then, I'm working MIDI device controler project, with the Arduino MIDI Library Version 3.2.
Now, I don't find a way to store in an array the entire SysEx array comming from my midi device.
I however do get the correct SysEx array length with the following:
#include <LiquidCrystal.h>
#include <MIDI.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
lcd.begin(16, 2);
MIDI.begin(MIDI_CHANNEL_OMNI);
MIDI.read();
[b]unsigned int a = MIDI.getSysExArrayLength ();[/b]
lcd.setCursor(0,0);
lcd.print(a);
lcd.print(" ");
But now, I also would like the entire Sysex Message array to be stored in a variable, and I don't succeed... I tried with the following:
byte * Myarray = MIDI.getSysExArray();
There is an error message when compiling the sketch which is:"error: invalid conversion from 'const byte*' to 'byte*'"
I also tried to do it without the pointer:
byte Myarray[] = MIDI.getSysExArray();
And now the error is: "initializer fails to determine size of 'Myarray'"
Ok so I will give the size :
byte Myarray[a] = MIDI.getSysExArray();
And another error appears: "variable-sized object 'Myarray' may not be initialized"
If someone could tell me "how to", that would be very nice
Lionel
