MIDI-Hairless-Ableton Live
can someone help me out? i got it to work from the tutorial but i cant get any further.
i am able to control the colors and blink the lights but i have no idea how the code works. I even got it to work with a music recording program ableton live. but still dont know how it works. therefor i dont know how to customize it.
I used this tutorial
like i get how a basic code works like setup and loop etc. but when i try to break this code down i cant seem to understand.
my video
 * Basic MIDI Visualizer
 * by David Madison © 2017
 * www.partsnotincluded.com
 * This is a basic MIDI visualizer using addressable LEDs, to demonstrate how
 * Arduino's MIDI library works. Playing a note turns an LED on, stopping a note
 * turns the LED off. Continuous controllers 21, 22, and 23 adjust the RGB color.
#include <FastLED.h>
//#include <Adafruit_NeoPixel.h> // Uncomment if you're using RGBW LEDs
// ---- User Settings --------------------------
#define DATAPIN 6
#define NUMLEDS 18
#define BRIGHTNESS 255
#define BAUDRATE 115200 // For Hairless
#define NOTESTART 40
// Continuous Controller Numbers
static const uint8_t
  redCC   = 1,
  greenCC = 2,
  blueCC  = 3;
// Settings
  Pin = DATAPIN,
  NumLEDs = NUMLEDS,
  minNote = NOTESTART,
  maxNote = minNote + NumLEDs,
  maxBright = BRIGHTNESS;
// LED Color Values
uint8_t
  rVal = 255,
  gVal = 255,
  bVal = 255;
// Build the LED strip
#ifdef ADAFRUIT_NEOPIXEL_H
  Adafruit_NeoPixel strip = Adafruit_NeoPixel(NumLEDs, Pin, NEO_GRBW + NEO_KHZ800);
#elif FASTLED_VERSION
  CRGB leds[NumLEDs];
#endif
boolean ledState[NumLEDs];
// Create the MIDI Instance
#include <MIDI.h>
struct CustomBaud : public midi::DefaultSettings{
    static const long BaudRate = BAUDRATE;
MIDI_CREATE_CUSTOM_INSTANCE(HardwareSerial, Serial, MIDI, CustomBaud);
void setup(){
    strip.setBrightness(maxBright);
    strip.begin();
    strip.show();
    FastLED.addLeds<WS2812B, Pin, GRB>(leds, NumLEDs);
    FastLED.setBrightness(maxBright);
    FastLED.show();
  #endif
  MIDI.setHandleNoteOn(handleNoteOn);
  MIDI.setHandleNoteOff(handleNoteOff);
  MIDI.setHandleControlChange(handleControlChange);
  MIDI.begin(MIDI_CHANNEL_OMNI);
void loop(){
  MIDI.read(); // Check for MIDI messages every loop
void handleNoteOn(byte channel, byte note, byte velocity){
  // Check if note is in range
  if(note < minNote || note > maxNote){
    return;
  ledON(note - minNote);
  show();
void handleNoteOff(byte channel, byte note, byte velocity){
    return;
  ledOFF(note - minNote);
  show();
void handleControlChange(byte channel, byte number, byte value){
  switch(number){
    case redCC:
      rVal = map(value, 0, 127, 0, 255);
      redraw();
    case greenCC:
      gVal = map(value, 0, 127, 0, 255);
      redraw();
    case blueCC:
      bVal = map(value, 0, 127, 0, 255);
      redraw();
void ledON(uint8_t index){
  ledState[index] = 1;
  setLED(index, rVal, gVal, bVal);
void ledOFF(uint8_t index){
  ledState[index] = 0;
  setLED(index, 0, 0, 0);
void setLED(uint8_t index, uint8_t r, uint8_t g, uint8_t b){
    strip.setPixelColor(index, r, g, b);
    leds[index].r = r;
    leds[index].g = g;
    leds[index].b = b;
  #endif
void redraw(){
  for(int i = 0; i<NumLEDs; i++){
    if(ledState[i] == 1){
      ledON(i);
  show();
void show(){
    strip.show();
    FastLED.show();
  #endif
I think you need a MIDI host such as loopmidi which shows up in the DAW as a device. The Hairless MIDI-Serial only takes care of the conversion from serial data to MIDI (and vice versa) so you'll need to route that somewhere. The board will most likely show up in Hairless as a COM-port which you'd then connect to the loopmidi.
This is based on my experiences with an Uno, there are a number of MIDI hosts (Jack, MIDIOX etc) but loopmidi was the only one that worked.
i got it to connect and work. but how can i customize it?
ok more specifically what does "uint8_t" mean in the code? i have never seen this anywhere.
beensolo:
If I was to throw a guess I'd say it's an unsigned integer or something.
efinque:
Yes, an 8-bit unsigned integer. See: http://www.cplusplus.com/reference/cstdint/
