Midi - How to change program channel
Hello,
I am confused on how to change the channel of the program command in MIDI.
What I am trying to accomplish is to change the program (instrument) on channel 1, 2, 3… instead of the default 0.
Using noteOn analogy:
void noteOn(byte channel, byte note, byte attack_velocity) {  //Send a MIDI note-on message.  Like pressing a piano key
  talkMIDI( (0x90 | channel), note, attack_velocity);        //channel ranges from 0-15
I thought this would work for program change :
talkMIDI(0xC0|channel, instrument, 0);
But it is not changing the channel instrument ( changing channel to 1 or 2)
Anyone know how to change the channel using the change program command?
Yes that is how to do it.
Except you must send it to the channel you want to change, so did you change the channel variable to 1 to send it to channel 2.
Also program change only requires two bytes so don’t add the ,0 as a third parameter.
I am not familiar with that library so don’t know if there is any other call.
Then send all your note on / off messages to this new channel.
Thanks Mike. It is working. Silly me was using noteOn on different channel.
