MIDI in Code, without MIDI Library
Hi, here is a code snippet i use with great success in an arduino midi controller, it does not use the midi library and the code is therefore much smaller. also i had problems using the midi library with an arduino micro, it messed up the usb connection and i had to reflash via headers…
this code handles all the midi messages (with running status) except for system exclusive messages.
so, i thought i share, please correct anything that could be more efficiently done (for speed)! this is based on grumpy mikes code, so thank you grumpy mike!!
//some random cc numbers:
#define SAVE_CC 120
#define CHANNELMODE_CC 119
#define FULLLEGATO_CC 118
#define OCTAVE_CC 117
#define STICK_CC 116
//midi in variables
byte state = 0;
byte statusByte;
byte dataByte1;
byte dataByte2;
  //start serial with MIDI baud rate 31250 or another standard speed for debugging
  Serial.begin(31250);
MidiIn();
void MidiIn(){
  if (Serial.available() > 0) {
    // read the incoming byte:
   byte incomingByte = Serial.read();
   switch (state){
      case 0:
      if (incomingByte > 0x7F && incomingByte < 0xF0 ){    // this reads all statusbytes, realtime stuff is ignored
         statusByte = incomingByte;
         state=1;
        if (incomingByte == 0xF0) state=3;
       case 1:
       // get first databyte
       if(incomingByte < 0x80) {
        dataByte1 = incomingByte;
        //check for two byte messages...
       if ((statusByte & 0xF0) == 0xC0 | (statusByte & 0xF0) == 0xD0) {
        midiParser();
        state = 0; //reset state machine
       } else state = 2;
       } else{
      state = 0;  // reset state machine as this should be a note number
       case 2:
       // get second databyte
       dataByte2 = incomingByte;
       midiParser();
         state = 0;  // reset state machine to start
          //stay here for sysex, wait for it to end...
         case 3:
         if (incomingByte == 0xF7) state=0;
         if(incomingByte > 0x7F && incomingByte < 0xF0) {
              state=1;
void midiParser(){
  switch (statusByte){
    case 0xC0: //program change
    //do something when a program change arrives, prg nr is dataByte1
    case 0xB0: //cc messages
    switch (dataByte1) {
      case SAVE_CC:
      //do something here
      case CHANNELMODE_CC:
      //do something else
      case STICK_CC:
      //again something on this cc
      case FULLLEGATO_CC:
      //you get the idea
      case OCTAVE_CC:
     //octaves!!!
Hi, I was wondering If you could help me use your method to change this code so that the MIDI library isn't used. I am trying to convert it to raw c, or c ++. Can PM you ? Thanks
Maybe you could have a look to my light midiXParser class released to the open source community, handling also everything from basic midi messages, and more complex like running status and sysex. https://github.com/TheKikGen/midiXparser
example :
midiXparser midiParser;
midiParser.setChannelVoiceMsgFilter(midiXparser::noteOffMsk | midiXparser::noteOnMsk );
loop()
    if ( Serial.available() && ( midiParser.parse( Serial.read() ) {
    // Do something for notes on/off
This is more "low level" than the very good midi library from FortySevenEffects but it does the job quite well. A bunch of tests are provided with the demo INO sketch...
lokki:
and it is not possible that the MIDI library messed up your board…it is probably your hardware causing that.
Remember that USB serial and Arduino UART share RX & TX, so you must isolate them with a switch…or disconnect MIDI cable.
