Mem pointed you in the right direction for the code I thought.
If you must do the USB route, probably simplest to make a helper application in Processing that will read the MIDI stream and echo it (or some abstraction thereof) to the Arduino. MAX/msp also has ability to send specific data to serial ports on MIDI command.
I'd really look into going with MIDI cables, though; if you are going to be using an external keyboard, that would mean you could pick up the data on your Arduino without needing to plug both into another computer just to handle the USB issues.
hi guys,
i just got an arduino two days ago in hopes of making a midi -> din sync, cv/gate, and dcb converter. i have midi in to cv/gate and din sync working.
/* MIDI to CV/Gate converterError in HZ due to 256-bit resolution of PWM (f_desired - f_synthesized)
0 A0
0.0988 A#0
-0.2105 B0
-0.1113 C1
Hey, cool idea, doing it with PWM! But how audible is the Hz error in the upper octaves? Has anybody meassured the real errors using a 10bit DAC chip or high accuracy resistor ladder version?
I guess the errors would stay easily below 1% even on a 0-10V range... I'd like to emulate smooth glides/portamento with an analog feeling
How good are commercial MIDI to CV converters?
Cheers, Oli, planing to build a MIDI/CV converter for his tenorion ![]()
I was just writing my own MIDI2CV sketch and ran across this one - very excellent. thanks for posting it!
The PWM works fairly well once smoothed with an RC-lowpass filter but (predictably) lags a tad in response time, relative to the capacitor used.
I was thinking about using an R2R DAC ladder instead - will post results.
Ok I have been trying out the code for the midi/cv converter. What values are you guys using for the R-C filter for the pwm output? anyone have a diagram of that bit?
thanks!
hi there,
I'm using a 2nd order filter
r = 47k
2r = 100k
c = 22nF
1/2c = 100nF
cheers,
Fedde
Im fairly new to Arduino programming, but Im getting there. I have so far tried all of the midi-in programs on this thread, but what I really want to do is get the Arduino to play a simple square wave, for every note sent via MIDI.
I originally thought of using joshatkins MIDI to CV/gate converter, to control an external oscillator, but surely the Arduino should be able to generate simple tones. Does anyone know how to go about modifying the CV/ate converter code to do this?
0 A0
0.0988 A#0
-0.2105 B0
-0.1113 C1
0 C#1
0.1245 D1
-0.2652 D#1
-0.1402 E1
0 F1
0.1569 F#1
-0.3341 G1
-0.1767 G#1
0 A1
0.1977
-0.4210
-0.2226
0
0.2490
-0.5304
-0.2805
0
0.3138
-0.6682
-0.3534
0 A2
0.3953
-0.8419
-0.4452
0
0.4981
-1.0607
-0.5610
0
0.6275
-1.3365
-0.7068
0 A3
0.7906
-1.6838
-0.8905
0
0.9961
-2.1215
-1.1219
0
1.2550
-2.6729
-1.4135
0 A4
1.5812
-3.3676
-1.7809
0
1.9922
-4.2430
-2.2438
0
2.5101
-5.3458
-2.8270
0 A5
*/int gatePin = 4;
int cvPin = 5;
int statusLED = 13;
int midiEnable = 2;
byte notes[] = {0,4,9,13,17,21,26,30,34,38,43,47,
51,55,60,64,68,72,77,81,85,89,94,98,
102,106,111,115,119,123,128,132,136,140,145,149,
153,157,162,166,170,174,179,183,187,191,196,200,
204,208,213,217,221,225,230,234,238,242,247,251,255};
int tempo = 1;void setup() {
pinMode(gatePin, OUTPUT);
pinMode(cvPin, OUTPUT);
pinMode(statusLED, OUTPUT);
pinMode(midiEnable, OUTPUT);
Serial.begin(31250);
digitalWrite(midiEnable, HIGH);
}void loop() {
readMIDI();
}// play a note out to cv
void note(byte note, byte velocity) {
analogWrite(cvPin, notes[note-9]);
if(velocity == 0) {
digitalWrite(gatePin, LOW);
digitalWrite(gatePin, HIGH);
}void blink(int repeat) {
for(int i=0; i<repeat; i++) {
digitalWrite(statusLED, HIGH);
delay(5);
digitalWrite(statusLED, LOW);
delay(1);
}void readMIDI() {
byte incomingMessage[] = {0,0,0};
byte incomingByte = 0;if(Serial.available() > 0) {
incomingByte = Serial.read();
delay(3); // not sure why i need to delay here, but doesn't work w/o it
if(incomingByte >= 240) {
readSystem(incomingByte);
incomingMessage[0] = incomingByte;
incomingMessage[1] = incomingByte;
incomingMessage[2] = incomingByte;
}processMIDI(incomingMessage);
}void readSystem(byte incomingByte) {
byte incomingMessage[] = {0,0,0};// read in the system message
incomingMessage[1] = Serial.read();
incomingMessage[2] = Serial.read();
}void processMIDI(byte incomingMessage[]) {
switch(incomingMessage[0]) {
case B10010000: // Note on, channel 1
note(incomingMessage[1], incomingMessage[2]);
case B10000000: // Note off, channel 1
note(incomingMessage[1], 0);
case B11111000: // Time code
tempo++;
if(tempo == 24) {
blink(1);
tempo = 0;
Thanks
wow, for a bare bones midi2cv is half bad! To reduce the glide or portamento between notes I replaced the 470uf cap in the rc filter with a 47 and 22uf. It was the lowest I could go without audibly impacting the cv out. The only bugs/problems Ive encountered are: Occasionally I will get a stuck note and when two keys are pressed it cancels the "note on" command. Anyone else experiencing this?
I have a r2r dac that I have been trying to use, with no luck. Its a AD7528 , from this pic based midi to cv I tried to make:, http://www.emusic-diy.org/Schematics/Misc/MidiCv?action=AttachFile&do=get&target=MIDITOCV.GIF and Schematics/Misc/MidiCv - E-Music DIY
even though the pic loaded properly, I could never get it working, even the gate. ?anyway...) I also have some dac0800's
Im still not sure how to change the code of the midi2cv to accommodate a dac or resistor bridge. The pin configs and labeling of the different dacs already posted about seem to vary so much that I cant seem to figure much out by looking at other examples. any thought or does anyone know of a real simple interfacing tutorial?
The keyboard glitches were with my keyboard. If anyone else is experiencing similar problems, try turnig off the internal clock in your synth.
I have been trying to modify this sketch by adding an additional cv out that works just like the pitch but coresponds to the mod wheel or an other assigned control and is used to modulate the filter, LFO or whatever on a Modular synth.
Here is what i have:
int gatePin = 4;
int cvPin = 5;
int modwheel = 3; // **declare mod wheel pin
int statusLED = 13;
int midiEnable = 2;
byte mods[] = {0,4,9,13,17,21,26,30,34,38,43,47, //**modulation steps
int tempo = 1;
pinMode(modwheel, OUTPUT); //** mod wheel as output
readMIDI();
void note(byte note, byte velocity){
if(velocity == 0) {
void mod (byte mod, byte velocity) { //** modulate function
analogWrite(modwheel, mods[mod-9]); //** modulate function
delay(5);
delay(1);
void readMIDI() {
delay(3);
case B00100001: //**mod wheel
mod (incomingMessage[1], incomingMessage[2]);
tempo++;
if(tempo == 24) {
blink(1);
tempo = 0;
My Additions are noted with **. So as you can see... not very original. Its really just a guess. I am trying to copy the pitch cv functons but have it correspond to the mod wheel. I was thinking that I only have to add a few lines to the MIDI processing to read the mod wheel and then another, above, to calculate the modulation steps and send pulses out.
Is the the correct approach?
It doesent seem to work, but there could be any number of problems. I thought that the mod" void mod" commands should have been with void note, but it wouldnt let be declare another variable (byte mod) in the scope. Also I am not sure if I have the right mod wheel message listed in the MIDI processing. 01 is the Mod wheel for midi in, but is different for out... or (more likely) am I totally wrong and need to take another approach
I looked at this, but I can't read code before I've had my coffee. Are you using running status here? That is the trick for things like mod wheels; you send the complete MIDI command only once, and then just keep updating the status byte.
Thanks nomuse..... Sorry, total novice here. Running status? ... Im not sure what that is exactly, but I dont think Im doing it. So in the case of this code, where should the running status line appear and do you have an example?
Here's the clearest explanation I was able to find in a quick search:
http://www.csie.ntu.edu.tw/~r92092/ref/midi/midi_messages.html
Thanks. I found that one too. So I get get what running status is but not how to do it. This is a little confusing because the sketch Im starting with list binary values and most of the other midi progams and tutorials use hexadecimal. Can I use both? ....I guess Ill keep searching.
